Doing a tune up on the Z28 and need some input.
Old Jan 25, 2013 | 01:06 PM
92camarodude's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Doing a tune up on my Z28 and this is going to be the first time for me doing something like this. I plan on doing plugs, wires, oil change, coolant flush, distiputer cap, air filter, oil filter, fuel filter. And was wondering if i should just use all ac delco parts and not bush or other brands? I'm using Mobil 1 5w-30 for oil since that's what i use in my Cadillac. I'm going to have my uncle while i'm doing this just in case if i get confused about something because hes a mechanic. Cars been off the road for a while anything else i should do while the car is up? And for wires i'm looking at some red ones that's all i know so if you can tell me brands you guys use.
Old Jan 25, 2013 | 07:09 PM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
Re: Doing a tune up on the Z28 and need some input.
Fresh gas?
Old Jan 25, 2013 | 07:44 PM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Originally Posted by TPI_BLAZER
Fresh gas?
Not fresh but there's STA-BIL Fuel Stabilizer in the tank and i'm gonna fill a gas can up with 93 octane to throw in it.
Old Jan 25, 2013 | 10:40 PM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
The list so far!
Fram/Air Filter X2 $8.99
Fram/Oil Filter $4.19
Fram/Fuel Filter $14.99
MSD/Wireset $87.99
ACDelco RpdFire Plat/Spark Plug $39.92
MSD/Distributor Cap $28.99
Mobil 1 5W-30 full synthetic motor oil $35.00
Prestone/50/50 extended life antifreeze and coolant $13.99
$243.05 total
Old Jan 25, 2013 | 11:37 PM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
The list so far!
MSD/Wireset $87.99
$243.05 total
Save some money buy AC Delco wires or the MSD StreetFire and basic AC Delco plugs....RTS45.. I think.
That cap come with a rotor? Shouldn't be that much.
Old Jan 26, 2013 | 09:24 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
The list so far!
MSD/Wireset $87.99
$243.05 total
You do not need Msd wires,get the regular stock wires for like $20. You do not need an Msd distributor cap either. Get a stock one,but make sure it has brass terminals.Brass doesn't get the corrosion like the regular caps do. Spark plugs should only be like $1.79 each too. Get the regular stock Ac Delco plugs. I would also run regular oil and just change it every 3k.
Old Jan 26, 2013 | 11:00 AM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Yep the Distributor Cap does come with a rotor. Reason i choose those wires is because they were red and i'm trying to get some red under the hood while still making it look stock. Where can i pick up those plugs? I don't see them listed on autozones site.
Old Jan 26, 2013 | 11:35 AM
ninetyone's Avatar
Axle/Gears: 3:42
Do yourself a favor and make sure that cap has brass terminals. Or else you will be cleaning them often. If you don't have headers I recommend the stock AC Delco Rt45
Old Jan 26, 2013 | 01:32 PM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Yea i do have headers and SLP loudmouths.
Old Jan 26, 2013 | 03:56 PM
ninetyone's Avatar
Axle/Gears: 3:42
If you have headers then the ac delco rt45 plugs are too long. What plugs and wires are you using now? You are using 90 degree boot wires right?
Old Jan 26, 2013 | 04:15 PM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
I have no idea on what wires or plugs are in her right now to be honest. You think i should just take her to some one so i don't screw up?
Old Jan 26, 2013 | 04:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
If you want wires that have 90 degree boots and work with headers go to Napa and order a set of wires for a 1980 Camaro v8. They are like $20. Pull out one of your plugs and see what they are. If you want shorter plugs that also work with headers ,order a set of Bosch 7985 plugs.
Old Jan 26, 2013 | 04:56 PM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Okay thanks a'lot for the help i'll order the spark plugs on summits site there only $1.50 each! And i'll look at the plugs when it gets a little warmer out.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Ranbo108
Sep 9, 2015 12:20 PM
z28guy134
Sep 1, 2015 11:50 PM
