Where does this vac line connect?
Old Mar 14, 2013 | 04:39 PM
Dirt Monkey's Avatar
On a stock TPI setup, where does this vac line connect? I heard a strange noise, found it was my PCV valve rattling. This line is pulling some serious vac. I belive it should be routed to booster?
Old Mar 14, 2013 | 05:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Where does this vac line connect?
Both the vacuum booster and pcv receive manifold vacuum signal. That port you pointed to is the vacuum signal for the pcv. Replace your pcv valve.
Old Mar 15, 2013 | 03:33 AM
Thats right, I guess i should have trusted myself -thats where I connected it when it all went together originally....PCV checked out ok, but replaced it anyway. The vac line was very pliable & could be pinched together easily. I installed I piece of heavy 3/8 line on there now. No noise at this time.
Old Mar 15, 2013 | 10:44 AM
gwalt584's Avatar
Dirt Monkey,
That looks like an FJ40 firewall?? are you putting that TPI in an FJ40?? I am doing the same. gwalt584 on IH8MUD, gwalt584@aol.com should you need to talk tech.
Gary
Old Mar 15, 2013 | 11:51 AM
Originally Posted by gwalt584
Dirt Monkey,
Gary
Yes, FJ40 I put the TPI in a couple years back. Had a brain fart yesterday though, Lol. Good luck. Its an easy swap really...
I just finished a Serp conv. I still had the V belts. Now the rig has TPI from a vette, and the serp setup from a Camaro. Had to adapt a Sanden a/c compressor over also(air compressor) of course the upper rad hose didnt work with the serp either, fan & water P rotation, alt moved, etc...Change one thing, and it snowballs into half a dozen others...fun, fun.
Old Mar 15, 2013 | 12:20 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
And make sure the the pass valve cover has a 90* elbow and vac line going to the 2nd vac port down on pass side of T-body
Old Mar 15, 2013 | 02:29 PM
I just have a breather on the pass side valve cover.
Old Mar 15, 2013 | 03:46 PM
TTOP350's Avatar
That works also but sometimes the tune needs a bit of a tweak on a MAF car. Not sure on th SDs.
Old Mar 16, 2013 | 03:46 PM
Hmm, interesting. I'll look into that. Im running SD.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Slush92RS
Sep 2, 2015 08:56 PM
