I need help with setup
Old Apr 5, 2013 | 10:35 AM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
I need help to make sure parts match. Putting together a base manifold with no manifold heat cross over, left and right runners have the small tube blocked as purchase, the plenum is a 1985 the TB is 1985 also. My question is should the two small tubes of both runners be plugged. Are the triangle shaped opening in the TB and plenum EGR passages I have EGR removed and blocked. Is this a working setup?
Old Apr 5, 2013 | 10:45 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: I need help with setup
If the plenum is a 85-88 if the egr has a block off plate no exhaust gas can go in to the 2 runners small tubes and up to the plenum y.
Old Apr 5, 2013 | 04:39 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I believe the triangular shaped openings in the TB and plenum are for idle air. If you have the egr removed and a block off plate installed, there is no need to plug anything.
Old Apr 5, 2013 | 10:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
85 - 88 plenums have two separate passages cast underneath ,
the pass side tube takes EGR gases up , the drv side one takes IAC air down
The tube on the drv side runner is the air supply to the CSI from the IAC passage on the TB
89 + plenum shown on left only has the EGR riser
Old Apr 6, 2013 | 08:55 AM
rongreen's Avatar
Thanks for your replies it also explains why I was having slow cold starts.
One more question converting a MAP Sensor and a MAP ECM...
If I converted to 1990 MAP with a 1990 ECM. WILL THE PARTS (85-88 plenum and TB) work with the plenum and TB that I have?
Thanks in advance!
Old Apr 6, 2013 | 09:28 AM
Engine: Lb9
Transmission: M20
You can use a map sensor on the older plenum just use a dedicated manifold vacuum signal .
https://www.thirdgen.org/forums/tpi/...tion-85-a.html
Old Apr 6, 2013 | 10:52 AM
rongreen's Avatar
Thanks tuned performance! Is the MAP sensor sensitive to the orifice size?
Old Apr 6, 2013 | 10:59 AM
Engine: Lb9
Transmission: M20
I'm not sure about the orifice size being a issues unless you are going smaller than the stock fitting witch is the same size that you have right now for your fpr.
The length of the vacuum hose will effect the map sensor try to keep it a foot or less.
Old Apr 6, 2013 | 09:12 PM
rongreen's Avatar
Ok Tuned Performance and thanks again guys for the help.
Old Apr 24, 2013 | 10:24 AM
rongreen's Avatar
Last night I began installing the intake manifold, runners, and plenum. Noticed that that the cylinder head port opening was slightly larger than the intake manifold opening more so in height than width.
A Fel-Pro 1205 was trimmed to fit the cylinder head opening (basically trimmed back to the blue raised seal) the intake manifold port is close to the Fel-Pro 1205 opening.
Question how much will performance lost will I be looking at or will it matter that much?
Thanks in advance
Old Apr 24, 2013 | 10:36 AM
Engine: Lb9
Transmission: M20
Nothing you can do, if it seals up run it. Your intake is the bottle neck especially if this is a larger displacement engine.
Old Apr 24, 2013 | 04:37 PM
rongreen's Avatar
How much hp will be added if the manifold was open to match the heads. Is it worth the effort to gasket match the manifold?
Old Apr 24, 2013 | 04:57 PM
Engine: Lb9
Transmission: M20
I'm really not sure you might pm this guy. I think he was going to have a few bases flow tested.
https://www.thirdgen.org/forums/member.php?u=45203
Old Apr 24, 2013 | 10:21 PM
rongreen's Avatar
Thanks Tuned Performance
Old Apr 24, 2013 | 10:34 PM
Engine: Lb9
Transmission: M20
np, wish I could have given you a better answer .
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
