Vortec Short block combo
If I were to replace my short block as well, and go to a 350 1996-2000 Vortec block #10243880, 1) would the TPI setup that I'm putting together using a scoggin-dickey or edelbrock intake manifold still work? Here is what I have so far. Also, do I need to get a 2-bolt main or a 4-bolt main?
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Vortec Short block combo
No need for 4 bolt mains there is no benefit until you get into the really high HP #s and RPMs.
EDIT: I just read that thread and you already have vortec heads. In that case you don't need a vortec block per say. Many people slap them on older blocks. So Just find any factory roller block and the edelbrock base you should be good to go.
Yea I'd like to do that. My concern is my 305 now has over 250,000 miles on it, so since I already have most of the upper engine, why not get a new(er) short block as well. Being on a budget I don't want to spend over $2,000.00 on a new block, which looking online seems like a majority of the price ranges lie. I found a company called MABBCO that sells remanned blocks, which looked more in my price range.
Car: 85 Trans Am
No I wouldn't put it on the 305 if that can even be done. But I meant by older block is they will bolt onto any 350 old or new. So your search doesn't need to be just for a vortec block. Just find a 87+ roller 350 short block and you are good to go.
You don't HAVE to use a newer vortec shortblock, but brand new or used, there are NO better GM smallblocks/shortblocks ever made, and they're cheap. Quite frankly there's no other block I'd use, unless I stepped into the aftermarket.
Car: 1992 Camaro Z28 Z03 Vert
Engine: 5.7L Vortec TPI
Axle/Gears: 3.23 Posi
I'm using that same block on my SD360VTPI motor.
Great combination... SD Vortec TPI intake, 350 roller block, headers and stock TPI and it runs like a beast. Sure beats the hell out of my old stock 305.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I've heard many bad things about MAABCO's quality control. I looked into them before I bought my ATK block.
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
z28smitty, so basically a worked 350 to 360 with mild re-bolted on items and s-d intake and you feel like it is a beast, how much for swap out and parts? How does your 360 compare to modern v6 and lt1 ls1 crowd
Well worse case I just go on ebay, grab a 350 block and have a machine shop rebuild it. Not my first choice but at least I could see whats being done to it.
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
We have 1pc seal short blocks in dish and flat tappet engines in stock....be hard pressed to be our price/quality. PM me if I can help, I dont get on here to much due to being so busy.
Brandon
ATK HP ENGINES.
Brandon
ATK HP ENGINES.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
LateNite89, if you want to make a trip to Vegas, I've got a crate 350 vortec block that was machined by the PO to .035 over, waiting for final decision on rings and pistons to do final machine pass. Engine had 30K miles on it- PO was going to build a drag engine. Have the block, caps, balancer. $150.
