Head Rebuild
Old May 7, 2013 | 11:15 AM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Head Rebuild
Alright I started rebuilding my heads since I blew a head gasket but I had to leave in the middle of it for military training and now I forgot where everything goes so I need some help.
First off in this picture.
The 3 bolts on the lifter guide thing, what torque are they suppose to be at?
Second
These are my new head gaskets, which side goes down? Hard to tell but in the picture it shows both sides, one side has little marks all over it while the other side is smooth in between the cylinders and other areas....
Third
On the head bolts, there was 1 that was shorter than the others and I don't remember what one that was....
Finally
On the back of the heads there was some holes, now I know one of those was for grounds but I don't remember which hole and what the others were for? Also I have these two sensors in the picture if you could help me with those.
Thanks for all the help, mean a lot.
Old May 7, 2013 | 11:53 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Head Rebuild
Gaskets should say this side up.
Two bolts on the end of the heads near rockers should be shorter. Of course the ones along the bottom of the heads are even shorter.
The bolts for the lifter hold down, I would locktight them, and snug them down.
Old May 7, 2013 | 11:56 AM
Car: 1971 Camaro
Engine: 427
Re: Head Rebuild
Dosen't mater which bolt hole the ground wire go in. Not all bolt holes are used.
Old May 7, 2013 | 12:06 PM
Re: Head Rebuild
Yeah, I would expect it to say which side goes down but it doesn't very weird...
And Thanks!
Any clue where those sensors go on the right side of the last picture? I think one was a knock sensor and i think the other is broken but not sure what they are or where they go?
Old May 7, 2013 | 12:08 PM
Car: 1971 Camaro
Engine: 427
Re: Head Rebuild
Can't tell from the pic.
What is the part number for your head gaskets?
Old May 7, 2013 | 12:21 PM
Re: Head Rebuild
Head Gasket is Victor Reinz part number: HS5745W
Old May 7, 2013 | 12:28 PM
Car: 1971 Camaro
Engine: 427
Re: Head Rebuild
I found this,
http://speedtalk.com/forum/viewtopic...=14176&start=0
Doesn't help much. Maybe it doesn't matter.
Old May 7, 2013 | 12:46 PM
Re: Head Rebuild
Alright, I guess I will just go with that, thanks for the help man.
Old May 7, 2013 | 12:56 PM
Re: Head Rebuild
O also for putting the lifters back, they are new and dry, should I put some kind of lubricant or engine assmbly lube somewhere or just soak them in oil or what?
Old May 7, 2013 | 01:16 PM
Car: 1971 Camaro
Engine: 427
Re: Head Rebuild
I soak lifters for 24 hours in new oil before installing.
ydnar417
Sep 23, 2015 05:57 AM
italiano67
Aug 31, 2015 06:04 PM
someone972
Aug 30, 2015 12:52 AM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
