Confirmation Please
Old May 20, 2013 | 02:18 PM
Panther1's Avatar
Confirmation Please
1990 IROC 350 TPI
There are 3 vacume ports on the plenum,passenger side rear. 2 small 1 larger I have 1 small hooked to fuel reg. the other small hooked to map or what ever that is mounted directly above the two small ports the larger port I have run to a one way valve that has 2 small lines coming off it, one goes to hvac the other runs to the front driver side I think to the vac ball. Is this correct?
Old May 20, 2013 | 06:24 PM
Panther1's Avatar
Re: Confirmation Please
,Must of had'em right. started right up no runs ,no drips, idles smooth. bosch 3's from southbay so far so good. Next Test Drive.
Veaceonee
Sep 29, 2016 08:15 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
tyeo098
Nov 30, 2015 06:27 PM
buckeyecelt
Sep 24, 2015 05:50 AM
89 formula TPI
Sep 7, 2015 11:06 AM
