what went wrong
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
what went wrong
I was running 9.0 in the 8th now I'm running 9.7 all I did was port out the plenton runners intake put new 22 pound injectors in and a egr block off what now thanks
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Re: what went wrong
the car will run leaner with the egr blocked off, i got a chip burned when i blocked mine off.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: what went wrong
Probably just need to go back to the track in cooler weather, with a cooler engine, it is August afterall.
Car: 89 Iroc
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
Re: what went wrong
Checked my timing on my car today and it was on 12 degrees I put it back on 6 it fills lot better hopefully run a 9.0 again
Car: 1983 G20 Chevy
Transmission: 4L60
Re: what went wrong
You need to look at Density Altitude before making these assumptions. It is very possible there is a gain there that is being masked by very high DA compared to prior track trips.
