checking for open loop or closed loop ?
Old Oct 4, 2013 | 07:28 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I am in the process running the code 13 diagnoses and was wonder how to tell if I am in open loop or closed loop thanks
Old Oct 4, 2013 | 07:34 PM
Twin_Turbo's Avatar
Jumper aldl. If the cel blinks fast it's open loop, slow is closed (crosscounts)
Old Oct 4, 2013 | 07:45 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
Re: checking for open loop or closed loop ?
great thanks
Old Oct 4, 2013 | 07:57 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok a little confused on the the method for checking code 13 after unplugging the 02 sensor should I run a wire from the o2 sensor wire to the terminal A the ground on the aldl thanks just trying to figure this code out.
Old Oct 4, 2013 | 08:14 PM
Twin_Turbo's Avatar
13 = O2 circitopen. Unpluig the O2 and w/ a DVM check for continuity between the pinout on the ECM and the O2 wire (will have to extend it to be able to get the 2 probes of the DVM hooked up) The pinout is D7, a purple wire.
Old Oct 4, 2013 | 08:25 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
thanks will give it a try need to find some longer leads for meter first
Old Oct 4, 2013 | 08:28 PM
Twin_Turbo's Avatar
or just get a wire and stick it in the oiriginal wir connector for the O2 to be ablt to connect the DVM. A helper holding the wire in may be handy. Personally, I always crimp a weatherpack pin to a wire to tet it but I know not everyone has these male and female weatherpack terminals available. You only need the terminal, not the seal and the housing for a quick check. Maybe your local vatozone or whatever has them and you can grab a couple and crimp one on.
Old Oct 4, 2013 | 08:48 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
cool thanks, wish you were my neighbor that would make it a lot easier. Should I have the ignition when checking thanks
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
