SLP cold air charcoal relocation
Old Dec 10, 2013 | 10:07 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
I just bought a complete slp cold air kit instructions are shity my only issue is how and were was a good spot next to the battery/radiator to installe the charcoal canister if you can provide detailed pics on a step by step that would be help full thanks
Old Dec 10, 2013 | 11:54 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: SLP cold air charcoal relocation
Inside the passenger side front fender ground effect, it wraps under the front right corner of the car. You can mount it in there, just extend the wires and vac lines.
Old Dec 11, 2013 | 09:10 AM
DiabloWS6's Avatar
That's a good idea but I wont pass visual smog check in California
Old Dec 11, 2013 | 05:36 PM
Stangski09's Avatar
Ya dont have that **** in Canada
Old Dec 11, 2013 | 06:20 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I was going to move my canister too. Does it have to be in the original location as well as present and functional to pass CA smog?
Old Dec 11, 2013 | 08:44 PM
DiabloWS6's Avatar
I dont know about the smog part about it but I want my charcoal canister to function and follow the slp instructions even though they are shity instructions
Old Dec 13, 2013 | 08:48 AM
DiabloWS6's Avatar
Slp cold air box doesnt fit have to force it in goint to remove my radiator since its no good leaks might make it easy to install and then the charcoal canister
Old Dec 15, 2013 | 05:43 PM
DiabloWS6's Avatar
The air box issue solved now is the charcoal canister I got it to fit snug but there is a harness that's on top looks to be the main headlights I need pics of how YOU who have done this before detail pics please not the crapy angles I have found on here dont do nothing for me
Old Dec 16, 2013 | 11:03 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Still be useful to know if the canister can be moved without changing functionality and still pass CA smog.
Old Dec 16, 2013 | 07:00 PM
DiabloWS6's Avatar
As soon as more people help out we will know the answer to that if I new I would tell you sucks that not many people are trying to help out
Old Dec 18, 2013 | 11:18 AM
B4CHawk's Avatar
Car: 2004 Mazda RX-8
Engine: 1.3l Renesis
Axle/Gears: \
If the canister is intact and functioning, there shouldn't be any issues. They don't care about location, just as long as it passes the test.
Old Dec 18, 2013 | 11:20 AM
B4CHawk's Avatar
Axle/Gears: \
Also; pics of the intake? For as many of these things as there are out there, no one has ever bothered to take a picture of it.
Old Dec 18, 2013 | 02:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
As long as it is mounted in the upright position it will still function OK. This is due to a liquid trap built into the lower area. I know this is true for the canisters with the solid bottoms.
Not sure how the ones with the filter on the bottom are built.
As far as it passing CA smog if relocated, that needs a CA referee to tell the tale.
RBob.
Old Dec 18, 2013 | 07:37 PM
DiabloWS6's Avatar
RBob.
This answered some of my relocation I guess the only spot is by the driver side I was thinkin of putting a lil side ways on the passenger bottom under the air filter location
Old Dec 18, 2013 | 07:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
What year of cold air kit do you have and what car is it in?
I bought/ installed several kits back in the day when new.
Old Dec 18, 2013 | 07:56 PM
DiabloWS6's Avatar
I have a 1986 trans am and bought a complete slp cold air kit for 88'-89'
Old Dec 18, 2013 | 08:14 PM
TTOP350's Avatar
Canister gets put between the power steering hard lines and the battery on the driverside. Sometimes the hard line needs loosened and moved out of the way then reinstalled to hold/wedge the canister inplace against the battery. (cheesy but that's how it was done)
When new, the kit comes with wire and hose to extend the vac line and electrical to that spot.
Old Dec 18, 2013 | 08:28 PM
DiabloWS6's Avatar
I seen that but at the bottom is the main headlight wire harness does it go on top of it
Old Dec 18, 2013 | 08:34 PM
TTOP350's Avatar
Just gets moved over to engine compartment side above the PS lines.
You may have to remove the harness from the clips for some slack.
Old Dec 18, 2013 | 08:40 PM
DiabloWS6's Avatar
Ah I will try that and both clips of the charcoal canister get screwed on to the frame rail
Old Dec 18, 2013 | 10:03 PM
TTOP350's Avatar
You can do that, I never did unless the owner wanted it that way.
I used Zip ties to help hold it in place so I wouldn't have to drill holes.
Old Dec 18, 2013 | 10:46 PM
DiabloWS6's Avatar
How and were did you use zip ties
Old Dec 18, 2013 | 11:05 PM
TTOP350's Avatar
You'll figure it out, it's not like we are wiring up space shuttles here. ;-)
I can't give away ALL my secrets!!!
Old Dec 18, 2013 | 11:16 PM
DiabloWS6's Avatar
True but im very closed minded and sometimes I cant see the easiest things but ill try
Old Dec 19, 2013 | 08:22 AM
Stangski09's Avatar
Cannister will fit under p.side battery tray upright, it will sit in there fine, you just have to move the metal tabs a little.
Old Dec 19, 2013 | 08:37 AM
TTOP350's Avatar
There are many places the canister can be mounted but for a SLP "correct" install, it get put on the driver side.
I've never had to pass a visual or have any type of EPA testing.
I installed mine here to cleanup the engine compartment.
Old Dec 24, 2013 | 04:11 AM
DiabloWS6's Avatar
Clean install
Old Dec 26, 2013 | 09:04 PM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
I have the slp cai on my 89 formula 350. I relocated the canister to the drivers side. I also used zip ties to hold it in place. If you want ill take some pics over the weekend and post them for you.
Old Dec 29, 2013 | 01:53 PM
DiabloWS6's Avatar
If you can please take some pics
Old Dec 29, 2013 | 03:50 PM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
Tell me if these help.
Old Dec 29, 2013 | 07:43 PM
DiabloWS6's Avatar
Yup these are great angle pics and in a good location to
Old Dec 29, 2013 | 07:48 PM
B4CHawk's Avatar
Axle/Gears: \
It would melt right off on my car in that location lol
Old Dec 30, 2013 | 06:22 PM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
Why would yours melt there. Because of headers or something. Considering the fuel lines are right there too im surprised you wouldnt have an issue with that then.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
