intake wont seal to heads
Old Feb 27, 2014 | 12:07 PM
Iroc21's Avatar
Car: 85,86 Iroc
Engine: lb9,l98
I removed my stock intake to install a used one which consists of plenum,accell runners, and stock base all ported by lingenfelter. The issue im having is the new base does not line up to the heads. I can barely get bolts started on either side of the intake and when I start to tighten them the intake doesnt seal against the head. My motor was supposedly rebuilt.
Could the deck or heads being shaved caused this issue?
Any ideas on the cause or solution?
Dying to get this intake on the car.
Thanks in advance
Old Feb 27, 2014 | 12:26 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: intake wont seal to heads
If your block was decked it could affect intake alignment.
Old Feb 27, 2014 | 01:30 PM
Iroc21's Avatar
Car: 85,86 Iroc
Engine: lb9,l98
Does this mean the original intake was shaved to fit?
I tried to mic the 2 intakes but could not get an accurate measurement due to the cast side
Old Feb 27, 2014 | 01:41 PM
midias's Avatar
Maybe, i have also noticed some aftermarket intakes just dont fit right and need a couplue holes oblonged
Old Feb 27, 2014 | 02:20 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I was thinkin this also. Is the intake for the 87-up heads? And I'm assuming your 85 has perimeter bolt valve covers
1992 Trans Am
May 10, 2023 07:19 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
