Does a reman ECU come with PROM?
Car: 1989 GTA and 1969 Dodge Charger
Engine: 5.7L...blah! It's a 350 baby!!!
Transmission: Automatic
So - I think I need a new (remanufactured) ECU. Do they come with the PROM?
I don't know which is bad... the ECU or the PROM.
Pep Boys sells a reman ECU for about $60.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Does a reman ECU come with PROM?
NO
You always remove your prom before doing any ECM exchange and fit it too the new unit
So now - I can go to start the car... and it will run like total crap. Missing, spitting/sputtering. I can turn it off... pull the key out... put key in... re-start it, and it will fire right up and run like a champ.
Other times it's the complete opposite. It will fire right up and purr... but if I shut it off and start it again, it will spit/sputter and misfire.
ECU? Prom?
ECU? Prom?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
IS this with a different ecm ? It sounds like a bad connection on the pcb for SAM .
Engine: Lb9
Transmission: M20
Pcb=printed circuit board
Sam= stay alive memory
Installed a reman ECU, with my same PROM. Car fired right up - sounds great. SES light immediately lit up.
Drove it about 10 miles, and checked the trouble codes at O'Reilly's Auto Parts. This is what it's throwing now:
46 -
45 -
44 -
42 -
41 -
63 -
61 -
54 -
52 -
51 -
So - it's the same codes as before, with the addition of 45 and 46 now.
Note: The guy I bought the car from said he was driving the car once when the battery tipped back, and the positive battery terminal contacted the inner fender. The car immediately died. After he told me that I thought: It probably screwed up the ECU... so I went ahead and replaced it. Nope. Didn't help.
What next? Try a new PROM?
46 -
45 -
44 -
42 -
41 -
63 -
61 -
54 -
52 -
51 -
Car: 1991 Camaro Z28
Engine: L98 350
Transmission: 700-r4
Axle/Gears: 3.23 posi disc brakes
I think I got a reman prom from advance auto parts online. It was a cardone for like 60 bucks.
KO1
16
Oct 15, 2015 05:00 PM
