Hard to find TPI coolant Manifold Fitting
Car: 91 formula
Engine: 350 tuned port. bolt ons
See pic Anyone Know where I can get this? would I find something to work at hardware store?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Hard to find TPI coolant Manifold Fitting
1/2 NPT
Maybe find something at a plumbing supply store
Car: 89 trans am GTA
Engine: 355
does it have to be new? just about any sbc chevy in the wrecking yard should have the same one. take a wrench and same some cash.
Car: 1989 TA
Engine: 5.0L
It can be new or used,doesnt matter,as long as it works. But,be careful starting to thread it into the manf,it may have metric threads and a standard pipe fitting might not work. IF there are metric pipe threads.
Engine: 4++,350 & 305 CIs
Its not metric, its npt.
Car: 91 formula
I just got back from the hardware store and found something and the plumbing department that would work. Its in NPT fitting that seems to thread in with no problem. now I'm only wondering should I use Teflon tape or some kind of sealant?
Car: 91 formula
What do you think of a pipe sealant? I was thinking of using that. Also what do you think of using that on the intake manifold bolts?
I use the paste on all water fittings and I do use it on the intake bolts to keep the oil in the valley and not puddle on the intake.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You can find them in the help section of auto part stores.
Car: 91 formula
I have found some non hardening pipe sealent in a hardware store. Ive read people us it on intake bolts. I plan on using alittle on the bolts. People seem to bash us of rtv on the bolts but ive see people say us rtv. Im in the middle installing an accel tpi intake manifold. I also still need to find an npt plug to intall on this intake. 85-88 intakes us this port.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
A company called "Murray" makes heater parts, they have that fitting.
Car: 91 formula
Yea temp sensor snaped off when i was removing it. Very brittle plastic after all those years better of replacing it. I ordered a new one off of TPI parts.net
Sanjay
Aug 12, 2015 03:41 PM
