New MAF Unit
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
New MAF Unit
Ive searched the forum for suggestions on a new MAF unit and mostly everyone was leaning towards micro-tech and wells (Su-145). But since i cant find a micro-tech and they stopped making wells has anyone tried richporter (64-1523) from carquest? Ive also came across that rock auto is advertising airtex/wells relays so are they the same company? If so ive come across a airtex MAF (5S2640) thats on sale on E-bay. Ive been through 2 bosch sensors, and they dont seem to work. Checked relays and they are ok.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: New MAF Unit
Car: 1989 Camaro IROC-Z
Engine: 5.7L
Axle/Gears: Borg-Warner/2.77 Ratio
Re: New MAF Unit
What about this one? It has a lifetime warranty.
http://www.1aauto.com/mass-air-flow-...ference=normal
Has anyone tried or used it? Only $140 and it's brand new
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: New MAF Unit
Normally 1450 bucks? Say WHAT?
Doesn't mention brand there at all. That would tend to make me nervous.
Engine: 5.7L
Re: New MAF Unit
Car: 86 IROC
Engine: 5.0 TPI
Re: New MAF Unit
yup, I have found NOS ones for $1500 !! mine cost $450. and truly I would have payed more just to be done with all the BS that a bad MAF brings. additionally the 89 design is different. but it will work on 86-89 cars . a big improvement IMHO. now as far as I can tell the 85 MAF is particular to that year. those guys are SOL.
Car: Camaro
Engine: 5.7 TPI
Re: New MAF Unit
I ordered the rich porter MAF and AC Delco relays today (MAF Power - GM 10067925) (MAF Burn Off GM 10094701) hopefully that will fix the issue, i also been seeing abnormal voltage drops on the battery gauge after the car throws the code. Does anyone car does this? I recently upgraded the battery cables, but personally I think i need more ground. Ill let you guys know how it went after I receive and install the parts. Thanks for your help
Art
Art
Car: 1988 GTA Trans AM
Transmission: 5 speed
Re: New MAF Unit
I too have been fighting a MAF issue, please let me know how it goes after replacing said parts
also on a side, i have found some info on relays and part numbers, for some cars the maf burn off and maf power relays were the same GM part, as my 88 GTA has same, number 14089936, design 2
http://www.hotrodhandbooks.com.au/eB...Line-10-1.html
Car: 86 IROC
Engine: 5.0 TPI
Re: New MAF Unit
Axle/Gears: 9-bolt/3.45
Re: New MAF Unit
The former Wells SU-145 MAF was supposed to be better and more durable than the stock MAF. It had a thick film/computer chip design, similar to the 4thgen MAF. And it was advertised as providing more air flow than the stock MAF. There are several old threads about it here on TGO. I believe Jim85IROC might have/had a Wells MAF, so perhaps he might offer his thoughts if he sees this thread.
The Airtex MAF looks like the Wells MAF and even wears a sticker with part number SU-145.
The Richporter MAF also looks like the Wells MAF. And the Duralast MAF from Autozone looks like the Wells MAF too. Both are listed as new, not reman, and both carry part number XX-157.
The Airtex and Duralast have price tags similar to the Wells MAF, whereas the Richporter MAF is listed at twice the price.
Web searches seem to show that there were patent issues with the Wells product, which might be why it's no longer available as branded. Regardless, as stated in this thread, the Richporter MAF is apparently excellent, so the other lesser-price brands with the same designs are probably also excellent products, probably even the same products.
Car: 86 IROC
Engine: 5.0 TPI
Re: New MAF Unit
BumpaD82
Feb 26, 2016 02:57 PM
1nastygta
Sep 24, 2015 08:58 AM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
