ALDL terminals...
Old 01-06-2015, 03:22 PM
jamiepz's Avatar
ALDL terminals...
Got an 88 5.7 GTA with run issues. Can you start and run car with A and B connected? Any way to make it stay in closed loop and bypass sensors?
Thanks for and info
Jamie
Old 01-06-2015, 10:40 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: ALDL terminals...
Unplug the O2 sensor, should stay in OL.
But why would you want this?
Old 01-07-2015, 10:42 AM
jamiepz's Avatar
Thanks for the info. I am kind of stuck. Trying to figure out why the car suddenly dies after a few minutes of running and it begins to warm up. It starts right back then dies untill let it cool off.sometimes starts a little rich. No SES and fuel press good.
Jamie
Old 01-09-2015, 05:58 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Thanks for and info
Jamie
yes you can start and drive the car with the A&B terminals connected. its called "field service mode" the CEL will flash depending on if its rich or lean. a factory service manual works wonders here as far as questions
Old 01-21-2015, 07:46 AM
jamiepz's Avatar
OK thanks for the help but im back to square one. No change. Appreciate the info.
Old 01-21-2015, 08:02 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It sounds heat related, check your basics, so you have spark/injector pulse after it dies, fuel pressure, ohming the injectors after it warms up and dies.
xodus2002
07-17-2020 09:08 AM
Veaceonee
09-29-2016 08:15 PM
WejaZ28
10-03-2015 07:38 PM
greenyone
09-08-2015 08:41 PM
Gunsbee
09-07-2015 07:10 PM
Quick Reply: ALDL terminals...
