valve seals
Old Mar 14, 2015 | 12:25 PM
brett89's Avatar
Car: 1989 Trans Am GTA
valve seals
Car is in storage. Been spending my winter buying parts I need for my car. I'm a little confused on the valve seals I need for my car. Is this the right part # I need for my stock 89 350 TPI. Felpro SS72527. I read I could possibly use these on the exhaust as well. Any input or options for better seals. Will be doing both intake and exhaust seals
Old Mar 14, 2015 | 12:31 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: valve seals
the idea is to use the very best valve stem seals for the application. I will point out that if you have valve guide wear, NO seal will be any good. and secondly the intake valve seals are the most important ones. sorry I don't have a part number for you. but I use fel pro stem seals. the kind that fit around the guide. they work very well
Old Mar 14, 2015 | 12:40 PM
brett89's Avatar
Re: valve seals
Thanks for reply. Not sure if theirs wear or not. It's got 32,000 miles on it. Was a garage queen before I bought it last year. I agree to use the best seals possible. That's why I'm asking. I'm new to these cars and not sure.
Any one else care to comment about using the felpro SS72527 seals for both intake and exhaust valves. Or is their better if so part numbers would really help me out.
Old Mar 14, 2015 | 02:17 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: valve seals
When you take the spring off the valve, pull the valve open maybe a half inch and wiggle side to side. you should have a slight wobble. very minimal, like a tho, maybe 2. (.001 to .002) I dont know the exact speck for your heads but I use that as a rule of thumb. If they are very loose I recommend K-liners. A brass liner that goes in the guide. A machine shop will have to install unless you have the tools to do it. There is a ton of different valve seals to choose from. I would research what works best on your style heads and valves. Deff dont put on those cheesy rubber ones.
Old Mar 14, 2015 | 02:25 PM
brett89's Avatar
Re: valve seals
"Deff dont put on those cheesy rubber ones". You pertaining to the felpros ?
Old Mar 14, 2015 | 04:25 PM
85Special's Avatar
Car: Silver 1985 IROC-Z
Transmission: 700-R4
Re: valve seals
My valve stems have a o ring grove below the keeper, think that's what he ment. Don't bother with those. I went the felpro rout, very happy with the results. Part # seems right, blue rubber on intake plastic umbrella for exhaust. Mine were killed by age, full rebuild 350 that sat for 12 years. Not sure about running intake seals on exhaust, I'm happy with the set up I have so I stopped digging for info.
Old Mar 14, 2015 | 10:13 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: valve seals
excatly what 85 special said. the good ones are a little tougher with a oring around the top and they kind of snap on. very cheep insurance. the cheesy ones are one piece soft rubber umbrella type. I will look for a pic to post!
Old Mar 14, 2015 | 10:18 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: valve seals
Like this.....http://www.ebay.com/itm/Metal-Clad-Viton-Valve-Stem-Seals-11-32-x-500-Chevy-sb-Ford-Chrysler-sbc-/321289080994?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ace5250a2&vxp=mtr
NOT this
http://www.ebay.com/itm/Viton-Umbrella-Style-Valve-Stem-Seals-Chevy-Ford-11-32-Valves-Small-Block-sb-/321289081384?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ace525228&vxp=mtr
hope this helps. And remember, always research what is best for your heads, guides, valves. Good luck mang!
Old Mar 14, 2015 | 10:21 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: valve seals
Another idea is call your local head shop and ask them. im sure they have oodles of them.
Old Mar 15, 2015 | 07:11 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: valve seals
I have used seals on both intake & exhaust . some will say it's a waste/not required . maybe so , they are cheap , easy to install , hurt nothing , why not . I even installed seals on all valves on a NEW G.M. crate engine I put in my car . just my thoughts , good luck .
Old Mar 15, 2015 | 08:03 AM
brett89's Avatar
Re: valve seals
Thanks for all the help guys. Much appreciated.
Aside from the seals, is their anything else I should replace while I'm in their ? Will be installed with heads on the car
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
