Timing problem
Old Mar 19, 2015 | 03:10 PM
Joker86's Avatar
Timing problem
Hey guys I need some help with my 86 trans am timing well I timed it my self and when I try to start it the car back fires but does not turn on. If anybody knows something that's will be great.
Old Mar 19, 2015 | 03:11 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Timing problem
You disconnected the est wire I presume, and what did you time it with?
Old Mar 19, 2015 | 03:22 PM
Joker86's Avatar
Re: Timing problem
Shine it at the harmonic balancer and move the distributor accordingly
Old Mar 19, 2015 | 03:30 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: Timing problem
So a timing light good. The two things you need to check are that you had the Timing light sensor connected to the right plug wire #1, and that the EST wire was disconnected. Beyond make sure to reconnect the EST wire when you're done. If it still acts up. Try disconnecting the EST wire and see if it runs ok.
Old Mar 19, 2015 | 03:43 PM
Joker86's Avatar
Re: Timing problem
Where is the EST wire located?
Old Mar 19, 2015 | 03:46 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: Timing problem
I runs to the distributor and has a connector in the middle.
Old Mar 19, 2015 | 04:00 PM
Joker86's Avatar
Re: Timing problem
It's on the passenger side right?
Old Mar 19, 2015 | 04:13 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: Timing problem
Yes
Usually tan colored with a black stripe
Old Mar 19, 2015 | 04:18 PM
Joker86's Avatar
Re: Timing problem
Yes
Ok I did but still the same problem. Would two vacume line that goes in to the manifold keep it from turning on cause I need to get two vacume lines cause it doesn't have it.
Old Mar 19, 2015 | 04:29 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: Timing problem
Are they open? Where the engine is sucking in air through them?
Old Mar 19, 2015 | 04:48 PM
Joker86's Avatar
Re: Timing problem
It's one of the tank press cont. valve and the other one is where is connected to the throttle body
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
