Need help identifing wire harness plugs
Car: 89 Iroc
Engine: 388CI Paxton supercharger
Axle/Gears: 4.10
Can anyone tell me what these plugs go to?? Both come from back of wire harness. male near the distributor and female near back of driver side valve cover.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Need help identifing wire harness plugs
Second one goes to the IAT under the plenum
Car: 89 Iroc
Axle/Gears: 4.10
I was thinking that cause I don't have a wire for the IAT sensor. This connector doesn't reach and is not the right connector. Is there a wire that plugs into this that connector and then plugs into the IAT??
Car: 88GTA
Engine: 5.7TPI
Dyno Don is right. And no, it plugs straight into the IAT Sensor Wire color is Tan and Black
Yes, there is a pigtail that goes to the sensor and it plugs into that connector.
Car: 89 Iroc
Axle/Gears: 4.10
Is the IAT and the MAT sensors the same? There is no way that wire reaches under the plenum and the connectors are different. The sensor I have under my plenum is the same as the coolant sensor
Car: 89 Iroc
Axle/Gears: 4.10
Ok that would make sense. Any idea where to get that pigtail? The car was stored in a buddies garage and I think he took a few things. I think that was one of them
