Serpentine routing without A.C or Smog
Old Nov 5, 2015 | 12:55 PM
R3500's Avatar
Installing a 90-92 SD TPI engine in a 94 Chevy truck. Only require the alternator and power steering pump. I have an extra A/C delete pulley...anyone out there running only the alternator and power steering pump via a stock TPI serpentine setup...if so how did you route the belt, have a belt part number?
The truck was diesel so I don't have the OEM SBC setup which probably wouldn't work with a TBI serpentine setup anyway because the TPI thermostat housing neck and air intake routing is not compatible with the TBI serpentine.
Old Nov 5, 2015 | 01:06 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Serpentine routing without A.C or Smog
Like this? https://www.thirdgen.org/forums/engi...ine-setup.html
Old Nov 5, 2015 | 05:14 PM
R3500's Avatar
Thanks...I couldn't locate that post....even uses the original belt. Noticed that the A/C delete I have has a smaller diameter pulley...won't hurt to have a new one anyway.
Old Nov 5, 2015 | 08:11 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Change the smooth tensioner pulley to a 6-rib pulley.
These are easy to find in plastic. The back / spokes won't perfectly clear the tensioner, some grinding will let it clear. Or a steel ribbed pulley should clear the tensioner.
No AC nor AIR pump delete pulleys needed.
Old Nov 7, 2015 | 06:42 AM
R3500's Avatar
Sounds more like what I prefer to do...you don't have a routing diagram or belt part number ..do you?
Old Nov 7, 2015 | 09:46 AM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
I have a set up like that in my bird I had to take a piece a string and wrap it around the pulleys in the pattern I wanted and then just went to the part store and find the right length on my tensioner itself the belt is backwards and the tensioner is at and odd angle so it doesn't have full movement but it works. I will post some pics here in a bit. I was going to switch to a ribbed pulley like JMD suggested but I totally forgot about it until I read this thread, and that has lasted me 3 years with no squeaking or extra wear
Old Nov 7, 2015 | 10:08 AM
nuggie's Avatar
Old Nov 8, 2015 | 03:19 PM
jmd's Avatar
jmd
Originally Posted by R3500
I have smog here and it's 120 in the summer; do you think I did that with my car?
You can route your belt like nuggie or you can wrap the water pump in between crank & power steering.
Hold the tensioner so the arrows line up, set up a string tightly, and measure the resulting string length.
Old Nov 8, 2015 | 04:10 PM
R3500's Avatar
Thanks guys...very helpful information!
Sooner84
Feb 1, 2016 11:40 PM
kaupca
Oct 23, 2015 06:14 PM
KO1
Oct 12, 2015 09:38 AM
rspeedyz
Carburetors
Oct 11, 2015 05:59 PM
atliia
Oct 11, 2015 11:10 AM
