Fuel Rail rebuild, found something interesting inside...
Old Feb 29, 2016 | 05:41 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
Founds this in one of the cross over rails by the regulator. I couldn't find anything on it in any manuals or after searching the boards. What is it's function and do I need it? I've been told it restricts gas flow or helps regulate pressure? Thanks.
5.7 TPI, 1988 Iroc
Old Mar 1, 2016 | 01:49 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Fuel Rail rebuild, found something interesting inside...
clean it and put it back ,
Old Mar 1, 2016 | 04:09 PM
tyrvidar's Avatar
Hehe.. well I guess that is how it goes then. I can't find **** on this little plastic bit anywhere.
Old Mar 1, 2016 | 04:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Hard to tell the actual size, but I wonder if it is an injector filter basket. That came loose and found it's way into the fuel rail. If it were me I don't think that it would be placed back into the rail. I know of no reason for something like that to be there.
RBob.
Old Mar 1, 2016 | 05:02 PM
tyrvidar's Avatar
RBob.
You my good sir are dead on, I just looked at the old fuel injectors did not catch it on first inspection, holy **** haha. Thank you!
Old Mar 1, 2016 | 05:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You're welcome, it just looked too strange to belong there. Glad to be of help.
I've also seen the pintle caps fall off of injectors and plug the injector port. Note that not all injectors have the plastic caps. But if they do need to check the port when installing new injectors.
RBob.
John Hagan
Interior Parts Wanted
Feb 7, 2016 10:06 AM
rock96
Feb 5, 2016 03:40 PM
JohnFB
Jan 31, 2016 06:47 PM
BobKnake
Jan 31, 2016 03:52 PM
hart67nova
Jan 31, 2016 07:57 AM
