LB9 cammed, dyno?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
LB9 cammed, dyno?
Anyone do just a cam swap in your LB9?
I rebuilt one, and I put a Ramjet 350 cam in it. (intake / exhaust duration @ 0.05 197/207 lift .430/.450 lobe centers 106atdc/112btdc lCL 109)
I have not done the heads yet (081 casting), but I'm just gonna re-lap and revalve with some comp 981-16 springs. Was gonna stick this in one of my boats.
Do you think it will make 260hp ?
-- Joe
-- Joe
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: LB9 cammed, dyno?
Wheels? No
Crank, might. Most bolt on L98's which very similar cam make 240-250's whp. Lb9 would be atleast 20 less, probably a good bit less like 30.
Engine: 4++,350 & 305 CIs
I did a ZZ2 cam in a 100% stock 92 305 long block yrs ago. put it in my car and ran 13.90s with it. (the car had tons of other mods and ran low 12s with the old 350)
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My 260hp 350 cid split 6" crack about 1/2" below the head from freezing. I'm going to try to epoxy it since it runs, doesn't seem to have water in oil, etc. But I have a feeling the epoxy won't work.
The 260hp is flat tappet cam, whereas the LB9 I have a roller cam. So I wonder if the roller cam, and being aggressive will make up for the lack of displacement.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 Firebird
Engine: 355 TBI
The 90-92 LB9 cam IMO is a better cam than the Ramjet cam. I know it doesn't have as much lift but it does have more duration. I don't see where there will be more power to gain by going with the Ramjet cam. Maybe your LB9 cam is pre-90 though before they got the L98 cam though? Still bet it can make 220-230 HP.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
202/207 .413/.428 114.5
So it has a little more duration and less lift, but a wider LSA.
Anyway, Ramjet cam is used because it's the cam approved for marine use. I'm not sure if the L98 cam might be an issue (with exhaust sucking water).
If I had through-hull exhaust, I probably would have done something different but I'm not trying to stray too far from normal.
What is interesting is the ramjet 350 cam is 280hp with 083 heads on a 9:1 350. That is quite a bit more than an L98, so it seems to be a better cam.
-- Joe
I'm betting the intake is the power difference
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 Iroc-z
Transmission: TH400
I also believe the L98's crank rating of 230-240 hp was not really accurate and actually under rated. They will dyno 210-220 in perfect form. 80% drivetrain efficiency, thats 260-270 crank
Car: 89 Firebird
Engine: 355 TBI
Totally agree with the HP being under rated. Ive heard several guys say they will dyno 210+ rwhp. Ive also seen a guy that was having trouble with his TPI put a carb on a stock L98 down to the horrible exhaust manifolds and it hit 13.9s at the track after running 14.4s with the TPI setup.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So, with all that discussed, do you think the LB9 with the Ramjet cam, iron dual plane and quadrajet will make 260hp or do you think the boat is going slower?? haha.
-- Joe
Car: 89 Iroc-z
Transmission: TH400
I think it will be close but something like the zz4 cam would be better imo
My 91 z is terribly slow. It supposively has L98 cam. I highly doubt it would run high 14's. My guess is 180 whp at best. Intake exhaust mods may get 200-210, hard to say. More cam would help imo
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The Vortec Marine engines are 300+hp, some EFI some still carb.
I've got piles of junk in my shop, but only one complete shortblock and it's starting to get warm out
I'm going to try and epoxy this thing tomorrow, but if it fails I'm going to have to use the LB9 with the Ramjet/mercruiser cam.
-- Joe
Car: 89 Firebird
Engine: 355 TBI
083 heads were the 350 L98 iron head. Much better " according to most" than the L05 #193 swirlport head. I could see it making 280 HP with the right intake and carb. Ive heard lots of folks say even the 081 TPI 305 head is better than the old 882s and 193s. Ive seen people run the 081s and do pretty well on 350 engines.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've got some L31 heads too I really need to get around to using on something..
-- Joe
Car: 89 Firebird
Engine: 355 TBI
Wish you were closer id like to get a good set they are hard to come by around here you may as well buy a new set.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
swirl port heads = a 1 time use boat anchor
