L98 350 Sensor Locations
Old Sep 10, 2016 | 11:54 AM
LS7L98TPI's Avatar
I have an L98 350 and I'm wondering what sensor is the one located next to the coolant temp sensor because I had a problem with my primary fan running all the time and when I disconnected the wire to this unknown sensor it shut off. I have a manual that says its the coolant temp switch but I cant find any other info on it
Old Sep 10, 2016 | 03:52 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: L98 350 Sensor Locations
I believe the coolant temp switch is what enables the cold start injector circuit.
Old Sep 12, 2016 | 10:32 PM
LS7L98TPI's Avatar
I wanted to know what sensor is the one left of the cts
Old Sep 12, 2016 | 11:22 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Again, that's the cold start injector switch. The coolant temperature sender is on the right.
IIRC, the way to keep them straight is the cold start injector switch has the same connector as the eight (nine) other injectors.
HTH (I just figured out what this stands for).
Old Sep 13, 2016 | 11:48 AM
LS7L98TPI's Avatar
Ok thanks.. Any idea why the fan shut off when I removed the connector
Old Sep 13, 2016 | 12:00 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Because with the connector unplugged, the ECM thinks the engine coolant is cold.
Old Sep 21, 2016 | 11:26 PM
LS7L98TPI's Avatar
Drivers side fan now comes on when u start the car for about 1 'min then goes off. Any ideas?
Old Sep 27, 2016 | 09:51 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Faulty sender.
Out-Cast
Sep 10, 2016 08:16 AM
thtanner
20
Sep 6, 2016 06:30 PM
Out-Cast
Sep 4, 2016 10:34 PM
Johnnycanso
Sep 4, 2016 06:07 PM
Cripley
Sep 4, 2016 02:45 PM
