Big cap dist
Old Oct 6, 2017 | 01:21 AM
Zipedoda's Avatar
Big cap dist
Will the big cap distributor fit under the tpi distributor cover? Thanks
Old Oct 6, 2017 | 01:34 AM
Drew's Avatar
Re: Big cap dist
Why wouldn't it? 85-86 F-bodys used a large cap distributor, so did the Corvette. The only time it's a problem is with the giant Accel Super Coil that covers the top of the cap, which is why Accel offered a stubby filler to replace the cover.
Old Oct 6, 2017 | 06:45 AM
ULTM8Z's Avatar
Re: Big cap dist
You have to make a couple of tweaks in the calibration that account for the size of the cap and it's effect on the ignition timing. The tangential speed of the rotor is a little faster on the larger diameter cap. It's basically a copy and paste from the Corvette calibration.
Old Oct 6, 2017 | 11:26 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Big cap dist
If you didn’t get one with the swap parts you purchased. RockAuto has them lookup a 85-91 corvette 5.7L.
Just make sure it’s computer controlled and has the flat 4 wire connector.
Old Oct 6, 2017 | 12:52 PM
Zipedoda's Avatar
Re: Big cap dist
Thanks for all the replies.
Old Oct 6, 2017 | 04:59 PM
ULTM8Z's Avatar
Re: Big cap dist
Yeah, if you see it with a vacuum advance cannister hanging off the side of it, that's not the one!
Old Oct 9, 2017 | 03:56 PM
marcial88's Avatar
Car: 1986 Camaro Z28
Engine: TPI 305 CI 5.0L V8 LB9
Transmission: AUTO 4 SPD 700 R4
Axle/Gears: 3.23 RATIO
Re: Big cap dist
I'll take the 3 relays for 15 bucks shipped. Text me at 1 323 532 9468 im i California.
Old Oct 10, 2017 | 02:08 AM
Engine: Lb9
Transmission: M20
Re: Big cap dist
No relays for sale here lol
Old Oct 10, 2017 | 06:27 PM
Vader's Avatar
Re: Big cap dist
Be aware that the TPI version of the large HEI cap is lower than the other (normal) versions of the large HEI cap.
Old Oct 11, 2017 | 11:38 AM
ULTM8Z's Avatar
Re: Big cap dist
Interesting... my large cap is the "carbureted" version. Yet it's on a computer controlled distributor.
Old Oct 11, 2017 | 06:03 PM
Vader's Avatar
Re: Big cap dist
The large cap was used on plenty of full electronic distributors, so that's no surprise. I believe the TPI version was primarily for clearance under the TPI plenum extension trim piece.
327_TPI_77_Maro
Oct 3, 2017 02:43 PM
Titan1833
Aug 23, 2017 03:49 PM
GOATS2QUICK
Aug 21, 2017 03:37 PM
devilfish
Mar 6, 2017 03:48 PM
zapc
Jan 11, 2017 06:45 AM
