1988 Trans Am Dumping Fuel... Noid light is solid
Old Jan 19, 2018 | 05:43 PM
1984tecate's Avatar
Car: 1988 GTA Trans AM
Engine: LB9 5.0 305
Axle/Gears: 3.45
Hey guys,
My 1988 Trans am GTA 5.0 TPI has been down for the last few months and the problem has now been narrowed down to the fuel injectors. The car would start and run for a minute and then stall because it was getting to much gas. When using the noid light it showed the injectors getting power all the time. Since the injectors are getting power all of the time they are continuously dumping gas into the cylinder and flooding out the car. I know the noid light should be blinking since it turns the injectors on and off. What will cause the injectors to stay on?
Old Jan 19, 2018 | 06:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1988 Trans Am Dumping Fuel... Noid light is solid
The ecm could be faulty grounding the injectors.
Old Jan 19, 2018 | 07:24 PM
Engine: Lb9
Transmission: M20
If you unplug the ecm and turn the key on and still have the noid light on the wires to the ecm from the injectors are shorted to ground. This would be the blk/pink and blk / light green wires.
Old Jan 19, 2018 | 07:25 PM
Vader's Avatar
...Or one of the injectors is shorted, grounding the whole lot.
Old Jan 19, 2018 | 11:24 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
This is a bad situation for the bottom end of the engine. Better drain the engine out really well and replace with some good oil and filter
Old Jan 20, 2018 | 12:13 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Measure the resistance between the terminals of each injector(unplugged) . Nominal is, IIRC (check for spec) 16 Ohms. If out of FSM range, replace the bad ones, or the entire set.
Old Jan 21, 2018 | 08:16 AM
1984tecate's Avatar
Engine: LB9 5.0 305
Axle/Gears: 3.45
The problem has finally been resolved. After changing the ECM and changing a few fuses it came back to life. Something must have shorted out and killed the computer. Thanks for the help guys
justin57
Aug 20, 2015 07:05 PM
Pablo
Mar 27, 2004 08:57 PM
Hoss50
Dec 24, 2003 12:18 PM
Project 92 RS
Jul 4, 2001 04:33 PM
