24x Conversion SBC wiring for sensors
Old May 2, 2018 | 02:31 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi All,
I am having trouble finding this answer, so I thought this would be the best place to ask the question and have the answer available to everyone, as it is a gap in the info available about this.
Question 1:
Using a Vortec distributor as the Cam Position Sensor, and looking down the connector at the pins, are these the correct wiring diagrams?
Where C= 12v (Red 39 on 0411 PCM)
B=signal from dizzy (Blue 73 on 0411 PCM)
& A= Low Reference / ground from PCM? (Blue 61 on 0411 PCM)
Question 2:
For the EFI Connection supplied 24x crank sensor, is the below diagram correct:
Where A=Sensor signal (Blue 12 on 0411 PCM)
B= Low Reference / Ground by PCM (Blue 21 on 0411 PCM)
& C=12v (Blue 2 on 0411 PCM)
I'll edit this once someone posts the correct CONFIRMED wiring.
If Pocket or Wildside can weigh in on this it'd be great.
Orr89RocZ
Dec 28, 2022 09:50 PM
S10Wildside
Mar 1, 2012 09:41 AM
S10Wildside
Sep 7, 2010 10:02 PM
S10Wildside
Aug 8, 2010 03:46 PM
