Error Codes 44, 32, 22, 21 - poor Idle and Emissions
Old May 26, 2018 | 02:14 PM
elnitschko's Avatar
Car: 1987 Chevrolet Camaro
Axle/Gears: Borg Warner
Hey guys,
I own a 1987 Chevrolet Camaro Iroc-Z28 (5.7l / 350cui, L98, automatic) and had some issues in the last time.
Mainly poor idle - in warm condition the engine does vary the rpm between 500-1500.
So I ran a diagnostic today and it showed some issues. Error Codes 44, 32, 22, 21 popped up. Here is a screenshot from the diagnostic tool:
Can anyone point me in the right direction / steps what to do now?
The engine is stock, has 105000 ml's. Only the exhaust is changed to headers without air tube. Also the A.I.R. system is removed (catalytic converter is still there).
I need to fix this so I can register my car.
Thanks for your help.
Max
Old May 26, 2018 | 04:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Error Codes 44, 32, 22, 21 - poor Idle and Emissions
With the error high and low for the tps you should check the v5 ref wire to the tps.
I would guess you have a bad tps or possibly a bad ecm.
http://chevythunder.com/tps_code_21.htm
http://chevythunder.com/tps_code_22.htm
Old May 27, 2018 | 02:30 AM
elnitschko's Avatar
Ok - that might help, I assume. I am not that professional in this type of diagnostics.
Does AC in the flow-chart stand for AirConditioning?
What is a test light? (In the chart for Code 21)
Jumper just means I have to connect the two cables (I think this is more of a language-barrierer).
Thanks for your help!
Old May 27, 2018 | 01:23 PM
Engine: Lb9
Transmission: M20
Your right ac is air conditioning.
This is a test light
Old May 27, 2018 | 09:56 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
When you get it fixed, take some pics, maybe even video of the car. A thirdgen running around europe must be kinda cool, especially when everything else is Fiat and VW.
Old May 28, 2018 | 12:55 AM
elnitschko's Avatar
Thanks for the Help.
I will Check that. I Just Hope there is No wire fatigue...that would be a pain to repair.
I will keep you up to date.
Yes. The 3rd Gen is quiet rare in germany. Also you See some Firebirds / Trans AM due to the 80s/90s Knight Rider Hype. But the Firebirds (espacially the 5.7l / 350 cui) ist not seen that often.
Old Jun 7, 2018 | 01:49 AM
elnitschko's Avatar
hey guys,
I found Out one thing that might be a problem.
I have an EGR Valve installed (I Heared some people remove it). I replaced Mine some time ago to try to fix my Error Code 32-Issue.
I recently found out that there should be an EGR Temp Sensor Attached to it...but there is None iny Car...the sensor is Missing and the Wire Just goes to ground (attached to the cars Chassis).
Is there any way to get the Sensor? I looked at Corvette Central but they Have a lead time of at least 3 Weeks (spoke to them via Mail)...Or has someone the Sensor and ist willing to sell IT?
I really Desperate and Just want to get my Car fixed within the necessary Regulation...
This Weekend I'll quickly Change and Check the o2 Sensor...Maybe that is the Problem for the bad exhaust values.
Old Jun 7, 2018 | 07:29 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
https://www.ebay.com/itm/EGR-Tempera...-/263099168515
Old Jun 8, 2018 | 03:28 AM
elnitschko's Avatar
Thanks,
somehow my eBay did Not Show that.
Is it possible that this Missing Sensor causes Error Code 32?
Greets
Max
Old Jun 8, 2018 | 05:17 AM
elnitschko's Avatar
Can I use this sensor AS Well:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F202316716379
The Shipping costs are much more reasonable on this one (:
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
Jeff f
Sep 24, 2013 04:47 PM
ak47
Aug 30, 2007 10:50 AM
jo88gta
Jul 14, 2003 08:08 PM
84camaroz28
Sep 24, 2000 06:27 PM
