Fuel injector question
Old Jun 23, 2018 | 07:33 AM
BM2's Avatar
BM2
Car: 1987 IROC
Engine: 5.7L
Guys- I'm looking to replace the injectors in my '87 L98. What are your thoughts on the best option for a direct replacement? The car is stock. I've searched the forum and it looks like many are using Bosch IIIs, but from what I'm reading tuning would be necessary and I'd prefer not to get into that (don't have the equipment, never done it before). Thanks,
Old Jun 23, 2018 | 01:11 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Fuel injector question
I used the IIIs and no tuning was needed.
Old Jun 26, 2018 | 08:09 PM
BM2's Avatar
BM2
Car: 1987 IROC
Engine: 5.7L
Thanks- will probably end up going with them.
Old Jun 26, 2018 | 09:06 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You have the best Bosch injectors, just have them cleaned.
Old Jun 29, 2018 | 11:29 AM
Davez1's Avatar
Car: 1988 Trans am
Engine: 305 tuned port
what about South Bay?
Old Jun 29, 2018 | 04:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Yes, South Bay sells the Bosch 3’s
Old Jul 4, 2018 | 06:47 AM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Can i ask here, please?
I have injectors from 87 vette and ECM from 91 camaro. Can be there any problems with ignitions? I have 5.0 injectors, but i think better use 87 vette, than 5.0 camaro.
What do you think?
Old Jul 4, 2018 | 10:51 AM
Engine: Lb9
Transmission: M20
If you have a 350 use the vette injectors. Unless thevinjectors have a grey body they are more than likely multecs. Multecs could short out with age.
Old Jul 5, 2018 | 05:00 AM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Thank you for your answer.
So i will use 87-89 vette injectors.
Old Jul 5, 2018 | 01:23 PM
Engine: Lb9
Transmission: M20
Those are a Bosch injector good quality. You might want to get them serviced before using them. Flow tested and new filter baskets and ohm the coils to make sure they are in good condition.
Old Jul 6, 2018 | 04:00 PM
BM2's Avatar
BM2
Car: 1987 IROC
Engine: 5.7L
An update: Ordered the IIIs from Southbay and installed them this week. Car is running beautifully (no hesitation/stumble - my initial problem). BLMs slightly lean under load, but not more than 142. Success!
Old Jul 6, 2018 | 04:54 PM
Engine: Lb9
Transmission: M20
A+ for southbay, now adjust your injector offsets
The last offsets I changed from the Bosch 3 sticky thread went to 118 blm.
Alittle rich. But runs great.
Old Jul 12, 2018 | 05:58 AM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Friends, i realy do not understand what differents beetwen 87 and 91 years injectors....
As i understand, they both 22 lbs.
Old Jul 12, 2018 | 11:17 AM
Engine: Lb9
Transmission: M20
The older injectors are Bosch. They are better quality than multecs.
They made both 19#hr for 305s and 22#hr for 350s .
Make sure you use the size needed for your engine.
They can be identified by the part number on the housing of the injector.
Old Jul 12, 2018 | 11:25 AM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Thank you very much for your answer.
So i should not need to remove my 1987 vette injectors from L98 1991 Camaro ?
I can use 87 corvette injectors on L98 Camaro 91? It is great new!
BUT... maybe you can help me... Exhaust manifolds still become red, when 2500x on "Parking" in 3-4 minutes... NO any "Check engine". Only 32, but it is my EGR, that i removed
Old Jul 12, 2018 | 11:32 AM
Engine: Lb9
Transmission: M20
I’m not sure if you have plugged injectors causing the extreme lean condition. This guy is experiencing the same thing.
https://www.thirdgen.org/forums/tech...extremely.html
Old Jul 12, 2018 | 11:58 AM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Thank you again!!!
Old Jul 13, 2018 | 07:19 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Injector balance test and smoke the intake if u can.
Old Jul 17, 2018 | 04:12 PM
southbay08's Avatar
Happy Days!!
Old Jul 24, 2018 | 07:11 PM
brando278705's Avatar
Car: 1987 Camaro IROC-Z
Engine: 5.7
Axle/Gears: 3.70
Bosch. Nothing else needs said!
Old Jul 31, 2018 | 11:34 AM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
Is it better to have the factory bosch’s rebuilt or order the Bosch 3’s?
Old Aug 1, 2018 | 08:50 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Order the 3s from southbay. Go and drive, watch fuel trims, and adjust offsets and burn a new chip if needed. For me it wasn't needed.
Old Aug 2, 2018 | 10:23 AM
southbay08's Avatar
Thanks Pro...
can you guys do me a favor? We were told by our web developer that the promo code was fixed however now i'm told by a customer that it's not.
If anyone tries to use the code on the website and it doesn't work please contact us. We'll place the order for you and give you the 10% off.
We continue to work on getting this issue rectified. Thanks for your patience.
Old Aug 4, 2018 | 11:16 AM
banksGTA's Avatar
Car: 87 GTA
I tried to place an order a few minutes ago An code didn’t work.
Old Aug 4, 2018 | 11:43 AM
southbay08's Avatar
uggghhhh….ok thanks for the heads up. Can you give us a call on Monday? We can place the order for you or if you have a paypal account I can send you and invoice which will include the discount.
Would just need your paypal address.
Old Aug 4, 2018 | 01:53 PM
banksGTA's Avatar
Car: 87 GTA
Yea I can jus call on Monday, that won’t be an issue. Thanks for the help.
Old Aug 5, 2018 | 09:42 AM
southbay08's Avatar
Sorry for the delayed response. We open at 9am NY time. So sorry for the inconvenience
516-442-4707
Old Aug 5, 2018 | 11:50 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
I didn’t even realize you guys offered a discount for members; I called and ordered a set (not the 3’s) from you guys this past week for my LB9. Got them in over the weekend but haven’t fired it up yet.
Old Aug 6, 2018 | 08:54 AM
southbay08's Avatar
we've been offering the same discount since 2008
Wilson
Jan 18, 2002 08:55 AM
formul8!!
Sep 20, 2001 02:09 PM
