Fuel pump options
Old Aug 8, 2018 | 10:59 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Fuel pump options
I need to replace the fuel pump in my 92rs 25th anniversary. The potential exists that I may go tpi, I already have the setup laying around. Should I consider installing a tpi fuel pump now and just regulate it down? What's the simplest regulator to install?
Old Aug 8, 2018 | 11:07 PM
Drew's Avatar
Re: Fuel pump options
On a 3.1? The stock fuel pressure regulator will work fine, it's the same as a TPI car anyway.
Old Aug 8, 2018 | 11:41 PM
GeneralDisorder's Avatar
You just need a fuel injection pump. Get a Deatschwerks 9-201-1029 for a C4 Vette. This will support up to about 600 HP and is durable, and nearly silent. We use a lot of the DW pumps and have never had a failure.
AEM 50-1000 would also be an excellent choice. Support about 1000 HP for $90.
GD
Old Aug 9, 2018 | 12:28 PM
draco's Avatar
Engine: 5.0l TBI
I'm so sorry, this was meant for the TBI forum, misclick.
I'm working with a 92 305 TBI, I have the tpi set laying around for that, not the 3.1l.
Old Aug 9, 2018 | 02:05 PM
Really doesn't matter - all the universal in-tank FI kits are pretty much the same. You just get a universal in the size you need and make it work. On the older stuff.... pre-96 or so, they all use the hanging steel tube pickup assemblies and it's just a matter of clamping the pump to the tubing and making sure it doesn't rattle around in there.
GD
J0hn_J0hn08
Mar 16, 2015 07:59 PM
Veaceonee
Jan 19, 2013 10:19 PM
kowboy59
Nov 7, 2011 09:36 PM
Coda79
Jun 25, 2005 08:51 AM
Marc 85Z28
Mar 26, 2003 09:23 AM
