91 z28 timing retarding bad...please help!!!
Car: 1991 Camaro Z28
Engine: L98 350
Transmission: 700-r4
Axle/Gears: 3.23 posi disc brakes
Can someone read my datalog? check out the timing being pulled with only 25 percent load! This thing is running with not much power. I have replaced the knock sensor, verified voltage at the sensor, made sure the new sensor was between 3500 and 4000 ohms. I'm looking for ideas on what to look for here.
Engine: L98 350
Re: 91 z28 timing retarding bad...please help!!!
Also, the base timing is set at 6 btdc, and less that 20k on the timing chain.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sorry didn’t look at your datalog. Just throwing out ideas. It your egr working. I have had a member I have tuned for that had pinging/timing retard when I disabled his egr in his tune.
Engine: L98 350
my egr is in fact blocked off and deleted. My problem started before that unfortunately though
Engine: L98 350
I'm still looking into this issue. I'm fixing to do a temporary knock sensor bypass with the 3.9k resistor on the knock sensor wire, and grounded. It will narrow down my field to the ignition module or the memcal since everything seems to be checking out by the flow charts. Hopefully my findings will help someone else
Engine: Lb9
Transmission: M20
Anjf or aujp memcal ?
Engine: Lb9
Transmission: M20
If you need one or a ecm I have both .
https://www.thirdgen.org/forums/engi...2-tpi-3-a.html
https://www.thirdgen.org/forums/engi...tpi-350-a.html
Engine: L98 350
I put in an acdelco d1984a ignition control module, and bumped up the base timing to 10 btdc and it runs great now. Thanks for the few that replied lol
ImportsRsloths
Oct 13, 2002 01:55 AM
ImportsRsloths
Aug 15, 2002 09:53 PM
