Help with code 54 now
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
my code 36 is gone
now code 54
do I just get a new fp relay
now code 54
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help with code 54 now
Check the voltage at the ecm b2. B2 would be if you have a 86-89 tpi maf 1227165 ecm. The ecm monitors fuel pump voltage there. It could be a bad splice on this circuit or the ecm.
Engine: 383 built
I have bbk underdrive pulleys and when I first used them 2 years ago it ideling didn't spin the alt fast enough to charge the car and it wouldn't start
so it was 12.2
so I got a way smaller alt pulley from a guy at a alt rebuild place by fluke he had one and I used it it was 13.5 to 14.5
I started getting the code 54 years ago after I put on those bb
so it was 12.2
Engine: 383 built
an update
I bought a new fuel pump relay and so far no code 54
so im happy time will tell.
BAD BLACK WS6
Nov 23, 2001 11:59 AM
