Confirming fuel line sizes
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I am cutting my oem lines down at the frame rail for -6an lines to my HSR. I ordered 3/8 and 5/16 compression to female an adapters. Will this work?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Confirming fuel line sizes
Your right on the line size. You can also flare the line to an and use a an fitting and tube nut.
Engine: Lb9
Transmission: M20
Iirc 5/16 is a odd size like an-5 jic
https://www.jegs.com/i/Earls/361/165156/10002/-1
https://www.ebay.com/itm/0318-05-Ste...sAAOSwStdbEJdF
Car: 85 Z28
Thanks for the help. I have both compression to -an adapters on the way. Now to route the braided lines away from my longtubes is gonna be the next fun part..
I'm going to need to do this to my fuel lines also but I don't have a clue as to what's required to get the job done. I know my lines are 5/16 and 3/8 like was stated. Any particular way this should be done? Do the compression type fittings tend to leak so a person should use the type that require the lines to be flared?
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
No, friction is the only thing holding the compression piece to the line. Under pressure it can push out of the fitting. This is why you don't use them for applications like fuel systems
Engine: Lb9
Transmission: M20
You can flare both lines to 37 degrees. You just need a tube sleeve and nut.
https://www.hoseandfittingsetc.com/p...eves/parker-tx
https://www.hoseandfittingsetc.com/p...ves/parker-btx
You also need to find a jic 5-6 male to male fitting. This might be the challenge.
parker makes one 6-5 HTX
https://www.hydradynellc.com/product...ion-triple-lok
https://www.hoseandfittingsetc.com/p...hts/parker-htx
https://www.speedwaymotors.com/Speed...ool,29380.html
You can get the an-6 in aluminum or steel. I prefer the steel. More robust.
I'd stay away from compression fittings in this application.....IMO, not a good idea
The_Phoenix
Nov 3, 2008 05:16 PM
