TPI intake painted silver at factory?
Old Mar 7, 2019 | 09:44 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Are these painted silver at the factory, or just plain aluminum? Got a quick look late night after pulling runners/plenum was having difficult distinguishing whether it was silver paint or plain aluminum.
Old Mar 7, 2019 | 09:51 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: TPI intake painted silver at factory?
Bare cast aluminum
Old Mar 7, 2019 | 09:53 AM
LiquidBlue's Avatar
Transmission: MD8
Originally Posted by TTOP350
Bare cast aluminum
Thanks! I'm considering popping it off and cleaning out the inside, from the looks of the insides of my runners it could use it. What are people using these days to clean? I read the old carb cleaners have been reformulated and don't work all that great anymore. (Didn't want to destroy silver paint in the process, good to know its bare cast)
Old Mar 7, 2019 | 10:45 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Having just gone through this myself, I took mine to the machine shop, had them hot tanked, then bead blasted. They look new.
On my own, and after a couple hours, they were not getting clean enough. Worth the money to get done right.
Old Mar 7, 2019 | 10:47 AM
Big&BadGTA's Avatar
My experiences:
https://www.thirdgen.org/forums/tpi/...-cleaning.html
Hot tank and bead blasted. Thanks for the tip!
Old Mar 7, 2019 | 10:58 AM
LiquidBlue's Avatar
Transmission: MD8
Thanks! Outside is fine. I'm interested in getting the inside clean, is it difficult cleaning the inside?
Old Mar 7, 2019 | 11:05 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Use a bottle brush with a flexible handle, and your favorite grease cutter. Either that, if you are feeling really rude, oven cleaner. If you go that route though, WEAR GLOVES.
Old Mar 7, 2019 | 11:29 AM
Drew's Avatar
Dish washer. "Pots and Pans". Just hide Helga's fry'n pan first, lest ye be wantin a concussion.
Old Mar 7, 2019 | 11:36 AM
Drew's Avatar
Seriously though, don't waste your time. The inside is naturally a chocolate brown color, the PCV system and EGR system circulate oil vapor and exhaust into the plenum. You can clean the inside spotless, and it'll start browning up again in short order. It's normal.
Old Mar 7, 2019 | 11:39 AM
LiquidBlue's Avatar
Transmission: MD8
Interesting, thanks for the tip.
87Silverhawk
Apr 4, 2010 04:27 PM
91RamAir Formula
Feb 21, 2002 07:44 AM
mult68
Dec 27, 2001 01:52 PM
