86 TPI 305 into 4th gen camaro start stall
Old May 18, 2019 | 03:43 PM
zftpi's Avatar
we have spark fuel and injector pulse the one thing we can see is our coolant temp switch is broken can this void the engine from idling? we have this mocked up basically we plugged all the vacuum lines with electrical tape and dont have the radiator hooked up yet. but were getting computer power and everything but is the coolant temp sensor needed to idle?
Old May 18, 2019 | 04:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 TPI 305 into 4th gen camaro start stall
The lack of cts should cause a rich running condition. If it’s the cold start timer switch that’s broken you will have alittle harder cold start.
Old May 18, 2019 | 05:35 PM
zftpi's Avatar
It's not rich in any manner but we're not running any coolant but we don't have a second module plugged in. It looks like a smaller version of the computer any ideas?
Old May 18, 2019 | 06:09 PM
Engine: Lb9
Transmission: M20
A small box like the ecm ?
Is this a 85 tpi with maf burn off module ?
Old May 18, 2019 | 06:35 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I don't think I ever have seen a 4th gen with a tpi swap.
Old May 18, 2019 | 07:07 PM
zftpi's Avatar
its an 86 305 tpi basically what im asking is what the frick is this thing?
5.5 MB
Old May 18, 2019 | 08:46 PM
Engine: Lb9
Transmission: M20
Your image is a link to gmail, you can attach your image here on tgo
Old May 19, 2019 | 12:49 PM
zftpi's Avatar
Old May 19, 2019 | 12:52 PM
zftpi's Avatar
I have no clue what is going on it starts and stalls I don't have any clue what codes are popping up as I don't have a scanner
Old May 19, 2019 | 03:16 PM
Engine: Lb9
Transmission: M20
Do you have the check engine light wires up ?
I have no idea what that silver box is. It’s unrelated to the efi.
Old May 19, 2019 | 06:04 PM
zftpi's Avatar
The check engine light comes on fine but I just don't have a scanner. Do I need a scanner?
Old May 19, 2019 | 06:42 PM
Engine: Lb9
Transmission: M20
A paper clip jumping the aldl a to b will blink the codes.
Old May 20, 2019 | 11:37 AM
zftpi's Avatar
I jumped a and b on the aldl and I got the 3 code 12s which I'm assuming is normal then 3 code 15s and followed by 3 more 12s which I've come to believe is the coolant temp sensor? I'm going to have to continue after work because my battery isn't charged. Any replies welcome.
Old May 20, 2019 | 04:40 PM
Engine: Lb9
Transmission: M20
Your correct the code 12 is normal and code 15 for the cts.
Old May 20, 2019 | 06:50 PM
zftpi's Avatar
I have code 15 33 and 43
zftpi
May 17, 2019 01:35 PM
N.W. WS6
Sep 6, 2001 07:19 AM
Gib_Sandwich
Aug 2, 2001 11:29 PM
