IAT RE-relocation
Old Jul 12, 2019 | 09:46 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
IAT RE-relocation
Had a quick question. I believe I've seen a few people do this and was curious as far as results. My car was originally a MAF setup but I switched over to MAP when I upgraded to an EBL. I relocated the MAT from the plenum to the air snorkel and went to a cage style IAT sensor. This location isn't as pone to heatsoak as the plenum however, the TPI snorkel being right above the radiator will still heatsoak the sensor at low speeds or when the vehicle is not moving. Even doing a few laps on test pulls, while pulling over for 3-5 minutes to write and flash a new tune, at key-on the IAT will report a temperature of 115+F and then gradually settle back down as the vehicle is driven.
I am getting ready to do a ram air through bumper setup and was thinking of relocating the sensor again to one of the air boxes. What would be effective and practical: Towards the bottom of the box near the nose or closer to the top of the box near the filter? I'm thinking that placing the sensor too low may make it susceptible to mechanical damage from rogue rocks or sticks.
Old Jul 12, 2019 | 12:47 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: IAT RE-relocation
I have wondered this: Relocation of the IAT or putting resistors in their place to show cooler air doesn't help.
You complain of heat soak, but the heat is soaking the air and is reflecting the temp of the air the engine is getting. Why is it better to lie to the computer and take a reading where the air is cooler? For true optimal tuning, wouldn't it be ideal to have an Air Temp Sensor in the actual intake runner (impractical I know)? It seems keeping it in the plenum gives the most accurate reading possible.
Old Jul 12, 2019 | 01:16 PM
Drew's Avatar
Here's something to think about. If the reading in the aircleaner is more desirable than the reading in the plenum, why didn't GM put the sensor in the aircleaner? They obviously understood it was possible, all the six cylinders had the sensor in the aircleaner. Why would they produce two systems, and different sensors, and deal with the complexity, when they could have just put the sensor in the aircleaner on everything?
On TPI it's not Iat, it's Mat.
Old Jul 12, 2019 | 01:22 PM
Car: 1985 Z28
Per the original post, the sensor is heatsoaking only at low or no movement because it sits directly over the top of the radiator. Not because the actual air going into the engine is that temperature. It's not "lying to the ECM".
TPI itself has nothing to do with the style of sensor. On MAF setups it was located in the plenum purposely to measure heatsoak. That's why it was referred to as an MAT. Its only purpose was to enable the EGR. On MAP setups, it was relocated to the air cleaner lid and actually influenced fueling calculations. It was then referred to as an IAT.
Old Jul 12, 2019 | 01:36 PM
RJ IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
I used to run that setup. I used ducting from the grill openings right to the bottom of the gutted filter panel. I ended up extending the IAT wiring, and I ran it in to the side of the ducting. It was protected from debris, and still did a good job of picking up temps. It was halfway up between the openings in the grille and the filters. I will say, that setup did a HELLUVA job keeping the air temps cool. I could go on an hour drive in 70 degree temps, and the plenum would be cool to the touch right after driving. It gets the filters pretty nasty QUICK.
I understand the difference in IAT and MAT, because I'm also living the EBL life. TPI only used the MAT for EGR, BUT the EBL uses it properly....as an IAT.
Put it somewhere in front of the filters. It'll be fine. Not like the sensors are terribly expensive. In the grand scheme of things, the IAT/CTS table will never be 100% perfect. Location of it is somewhat important, but I wouldn't lose too much sleep over it.
Old Jul 12, 2019 | 01:42 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Temperature relates to density, so no doubt influences fueling calculations.
I have both scanning software for the TPI's and my Challenger will display this information on the dash. Both exhibit similar bahvior... so did my TTA and my Mustang that I also used scanning on to read sensor data. The air is cooler at entry and temp will go up soem before entering the combustion chamber.
So to clarify, I am asking... why isn't it better to have it as close to the combustion chamber as possible? The sensor is reading the temp of the air in the area the sensor is... when air velocity goes up, temp drops quickly., but until then the slower moving air is affected by heat soak. This is the reason for ice bags at the strip.
What is the benefit at reading it near the filter rather than in the plenum? In a general sense, not just in the way the TPI was set up.
Old Jul 12, 2019 | 01:46 PM
Car: 1985 Z28
Thanks for your help once again RJ. That is exactly how I plan to set it up!
Old Jul 12, 2019 | 01:57 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Well gee... based off that logic you would have to think everything on the Thirdgen was perfectly optimized. Which it wasn't.. far from it on so many levels.
All Six cylinders did not have it in the Air Cleaners by the way. Near it sure, but not in it.
Old Jul 12, 2019 | 02:02 PM
Drew's Avatar
Witch Doctor Voodoo aftermarket ECM setups aside, MAF/MAP makes no difference. GM put it where they did on TPI for a reason.
I missed this squib, so nvm if your aftermarket witch doctor, voodoo, faith healing ECM requires something specific.
Old Jul 12, 2019 | 02:03 PM
Drew's Avatar
Shut it fool. I have zero time for your stupidity.
Old Jul 12, 2019 | 02:20 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Mine? You are the one that thinks 80's technology is 100% optimized.
Not to mention your statement:
Which they were not. Again I say, close, but in the tube. Also, Air Cleaner is two words.
So back to someone who make actually know the answer. What is the advantage to having the IAT reading the cooler air near the filter rather than reading the air temp closer to where it will enter the combustion chamber?
Old Jul 12, 2019 | 02:28 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
IAT/MAT is only really relevant when running in open loop in any event, otherwise, the O2 sensors are going to correct fuel mixture (injector pulse width) when in closed loop. No matter where you put it, it really isn't going to have that much (if any) of an affect on performance. All the 'magic chip' (inline resistor on IAT/MAT sensor) hype aside, if changing the value of one sensor, would yield 50 more horsepower, and 10 mpg better, it would have come that way from the factory.......
Old Jul 12, 2019 | 02:30 PM
Drew's Avatar
Did I say that, or are you putting words in my mouth?
Not to mention your statement: Which they were not. Again I say, close, but in the tube. Also, Air Cleaner is two words.
What do you call the piece of plastic or steel that houses the air filter? If attacking my spelling or grammar helps you compensate for being a buffoon, good for you.
So back to someone who make actually know the answer. Why is the advantage to having the IAT reading the cooler air near the filter rather than reading the air temp closer to where it will enter the combustion chamber?
"Why is the advantage" LOL And you want to be the grammar police?
See ya around Kyle.
Old Jul 12, 2019 | 02:35 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Yes, I know of the resistor and relocation kits that popped up over the years that were snake oil. But to the last statement... there are a few pulley/tune or boost controlled combos that you would have to make an exception for.
Old Jul 12, 2019 | 02:40 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Air Cleaner Housing, Air Cleaner Assembly? Maybe Air Filter Housing? Still, all V6 cars did not have them inside said housing. Some were in the tube near it.
Old Jul 12, 2019 | 02:41 PM
Car: 1985 Z28
I stopped replying to anyone after RJ because I had the overwhelming sensation that this thread was fast track on the way to turning into a crapshow. I can't say I was wrong
Old Jul 12, 2019 | 02:47 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
EBL flash moves it to the filter intake area on the TPI - its all in the tune guys.
Old Jul 12, 2019 | 02:51 PM
Drew's Avatar
My sincerest apology for trying to help you.
Old Jul 12, 2019 | 03:03 PM
Car: 1985 Z28
Case and point
Old Jul 12, 2019 | 03:19 PM
Drew's Avatar
Case and point
All I said was to think about why professional engineers designed a system the way they did. I already admitted I missed the part about the aftermarket ECM, and to disregard my statements if they don't apply. Anything that happened after that, I can't take responsibility for. Blame whoever you like, believe whatever you like, but I was trying to be helpful. Sorry if that offended you.
Old Jul 12, 2019 | 03:43 PM
Car: 1985 Z28
I can assure you that I'm not one of the one's on this post that took offense
89RS_82Z
May 21, 2009 05:14 PM
Sickness91Z28
Feb 11, 2005 02:39 AM
omcrider
Jun 12, 2003 10:04 AM
88blkiroc
Sep 21, 2001 01:01 PM
