TPI fuel line o ring flare
Old Jul 28, 2019 | 12:52 AM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
Anybody have a flare tool to do this style of flare? Or know where to buy a cheap one to do the GM o ring flare? Trying to make new hardlines to meet up to the factory rubber lines and need to make this flare on the end
Old Jul 28, 2019 | 02:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI fuel line o ring flare
I have the tool, it’s made by mastercool
Old Jul 28, 2019 | 07:30 PM
Car: 1992 Z28 1LE
Do you have a part number? Is it a real expensive setup?
Old Jul 28, 2019 | 07:39 PM
Engine: Lb9
Transmission: M20
Mine has several attachments, but you can get just the o-ring kit.
https://www.toolsource.com/flaring-t...t-p-91005.html
Old Jul 29, 2019 | 05:44 PM
Car: 1992 Z28 1LE
If I boxed up and shipped my hardlines I bent up for my T ram, and the tube nuts, is there any way I could talk you into flaring them for me?
Old Jul 29, 2019 | 06:28 PM
Engine: Lb9
Transmission: M20
Send me a pm, the line must be straight for a few inches in order for the die to work.
what do the lines look like, something I need for my t-ram
Old Jul 29, 2019 | 10:27 PM
Car: 1992 Z28 1LE
I’ll shoot you a note, and take some pics of the lines I have bent up and we will see if it’ll work! You can copy my lines for yours if you want
Old Jul 30, 2019 | 06:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Something like this helps a lot.
https://www.ebay.com/itm/TPI-Swap-Tu...kAAOSwDNdVws~r
Old Jul 30, 2019 | 11:12 AM
Engine: Lb9
Transmission: M20
Fragola 491970 and 491971
491963 and earl's 9894DBJERL
are the female to an6
are you using 3/8 feed and return or 5/16 return?
Old Jul 30, 2019 | 06:24 PM
Car: 1992 Z28 1LE
Old Jul 30, 2019 | 06:55 PM
Engine: Lb9
Transmission: M20
I measured the die is 1 3/4 long plus you have the distance of the tube nut I’m not sure what that is I don’t have any laying around.
looks like you have some flare on the tubes so you will loose some when that’s cut with a tube cutter.
seiplentz
Brakes
Nov 7, 2018 10:08 PM
92RS shearn
May 31, 2008 07:25 PM
BlackBird20
Brakes
May 23, 2006 03:25 PM
Abubaca
Mar 1, 2006 10:17 PM
graebz28
Sep 29, 2000 07:47 PM
