Serious Flooding
Old Jan 14, 2002 | 10:50 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Serious Flooding
I have a 72 LT1 Stingray with a 91 Vette speed density TPI setup installed. Has new 24Lb/Hr Ford motorcraft injectors and 58MM throttle body. On initial startup the engine floods severely. After warmup some flooding still takes place from acceleration and during shifts. The person I bought it from says he can only program standard chip profile. Who can I get to program a custom chip at a reasonable cost. I have Datamaster 8D software that I can record a session on and mail to someone for an analysis.
Old Jan 16, 2002 | 10:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Try Ed Wright at Fastchips.com, seems to have a decent rep with a lot of folks that have done conversions and upgrades.
Old Jan 16, 2002 | 11:22 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Not much info on webb site. How do I contact Ed
Old Jan 17, 2002 | 10:27 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Wrong address...it's www.fastchip.com
Old Jan 17, 2002 | 10:57 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
i'd hook an air fuel gauge up to your O2 sensor, and buy an AFPR for the car, and install it.
You can get it tuned a lot better without a custom chip with an afpr and something to monitor o2 readings.. I'm not gonna say perfect, but you can make a huge difference.
Old Jan 17, 2002 | 10:44 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
I don't know what an AFPR is or what to do with it. Just got off the phone with Ben Riggs alias TPIMAN1@aol.com. I have my MAP sensor mounted on the fender well. He recommends I move it close enough to the vacuum port on the plenum to use a maximum hose of 1 inch long. He feels that with the long hose I now have installed due to the remote mounting of the MAP is too much lag time in the signaling to the ECM causing an oscillation effect. I'll give it a shot this weekend. Let you all know the results.
Zane Story
Oct 8, 2015 12:40 PM
Wade787b
Sep 29, 2015 01:15 PM
jtmiller92
Jul 14, 2001 09:48 PM
Metalman
Carburetors
Jun 1, 2001 09:00 AM
82camarov6
May 3, 2001 07:43 AM
