Tranny problems
Car: 87 camaro
Engine: 88' 350 TPI
Axle/Gears: 10 bolt 3.42 Posi
Tranny problems
Hey Guys,
Anyone have any info about this. I had a dead battery yesterday and jumped the car then about five to ten minutes into driving car tranny was taking forever to shift into second and third gear and i had to drive real slow but eventually made it to overdrive gear and cruised for a while like that. When I came to stop and took off same thing happening with shifting. Then I parked car and shut it off for about an hour. Then got back into car and had no tranny problems at all. Is that something with the computer ??
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Tranny problems
Hey Guys,
Check basic stuff---TV cable adjustment and trans fluid level.
Car: 87 camaro
Engine: 88' 350 TPI
Re: Tranny problems
Fluid level is good I know there is a electronic type plug on the tranny. I thought that was for the computer ? Lockup stall speed? I thought the TV cable is for TBI's. I don;t have a TBI. Is that correct ?
Transmission: T-5, TH350, T-5
Re: Tranny problems
tv cable is for all engines that used a 700r4. The electrical plug is for torque converter lock up.
