Fuel leak
Old May 19, 2021 | 10:31 AM
Cadillacbart's Avatar
Car: 1984 z28 and 1987 Iroc
Engine: L69 305 and 305 tpi
Transmission: Manual 5 speed
Fuel leak
Hello,
I just picked up an '87 IROC with the 305. I know nothing about TPI system. I do see an obvious fuel leak . Can you tell me what the brass nipple is that I have pictured. It is literally wet with fuel. Should it be connected to something? capped?
Thanks,
John
Old May 19, 2021 | 10:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel leak
Could be schrader valve , crossover o-rings standard motor sk24 or flat washer under the test port it’s not brass.
Old May 19, 2021 | 10:40 AM
Engine: Lb9
Transmission: M20
Re: Fuel leak
https://www.thirdgen.org/forums/tpi/...der-valve.html
Old May 19, 2021 | 10:50 AM
Re: Fuel leak
Thanks. The fuel is in the center of the schrader valve, so that sounds like the culprit?
Old May 19, 2021 | 10:56 AM
Engine: Lb9
Transmission: M20
Re: Fuel leak
Yes don’t use one for a tire must be fuel rated. Simple fix
Old May 23, 2021 | 08:13 PM
Re: Fuel leak
The old schrader valve had a broken spring. Replaced with fuel rated version and new cap.
Thanks for your help.
IROC86MAN
Nov 2, 2011 09:33 PM
87_TA_GTA
Apr 12, 2011 11:13 AM
dankusman
Oct 2, 2010 04:34 AM
Fevre
Alternative Port EFI Intakes
Mar 26, 2006 09:28 AM
Ebby
Jul 24, 2005 01:47 AM
