Guys running 383's
Old Feb 11, 2022 | 06:29 AM
  #201
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Guys running 383's
Full throttle is good for new engines as long as it isn’t extended.
new engines need to mate surfaces and before that happens there are high spots wearing against each other. Which creates small hot spots.
so varied engine speed and load basically means drive it like normal and don’t be afraid to get on it from time to time.
As an example of new car’s, every new Focus RS got a full dyno before it rolled out of the factory to verify it was making the power it should. Before it even had 1 mile on the clock Ford already hammered the car for the equivalent of 2 or 3 quarter mile runs.
Old Feb 14, 2022 | 10:42 AM
  #202
Bill Chase's Avatar
Originally Posted by Fast355
I don't baby an engine at all! Foot to the floor from day one. I have actually had a few vehicles I bought with under 10 miles on the odometer. I actually pulled out of the dealership and stuck my 2012 Titan to the floor twice within a mile and it had 6 miles on the odometer. Ran well enough some people called it the factory freak in my local Titan group that went to the track. I ran my 2014 Titan at the local drag strip with less than 400 miles on it, dealer plates and all.
Have been told by many machinists I trust to heat cycle it a few times, check for leaks etc then as long as the tune is right to break it in the way you plan to drive it.
Old Mar 2, 2022 | 07:18 PM
  #203
ULTM8Z's Avatar
Figure a couple of youtube videos of the engine and having a little fun...
Old Mar 2, 2022 | 08:17 PM
  #204
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Nice
Old Mar 2, 2022 | 10:58 PM
  #205
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Glendale, were close. I'm in the Valley
Old Jan 8, 2023 | 04:13 PM
  #206
Bill Chase's Avatar
Originally Posted by skinny z
I'd say the most public benchmark is Vizard's Vortec 350. It made 447 HP with 224 @ .050" on a 108 LSA. They never gave the seat to seat specs (it's tagged as a custom grind from COMP) so it could be anywhere.
You've more cubes. Less cam. Better heads (IIRC). I'd say your odds are pretty good. Remember that 447 was optimized on the dyno. There's a lot to be said for that.
read a subsequent article on motortrend and he was quoted saying 3192 lobes were used.
Old Jan 9, 2023 | 07:16 PM
  #207
skinny z's Avatar
Somewhere along the line the spec goes sideways.
The 3192 lobe, which coincidentally is the intake lobe of the XE276HR and this is the cam I ran in my 2nd iteration of a Vortec 350 (the 1st being a copy of COMPs old school 268H), is 224@.050" as per Dulcich's original article from 2006. However that article goes on to say: "he selected a custom COMP Cams hydraulic roller single-pattern grind, with 224 degrees duration (at .050) on the intake and exhaust lobes, and 0.352 inch lobe lift".
The 3192 has a lobe lift of .378".
The Magnum 224@.050" profile has lobes with .333" and .350" so I don't know what's going on there.
The 3192 has an advertised duration of 276. The .350" lobe Magnum comes in at 280. Not a lot to choose between the two but it does affect the running compression ratio.
I always thought Vizard liked to lean on the Magnum profiles for whatever reason but this isn't to say that the magazine copy isn't wrong or DV's memory hasn't faded. Not that it matters I suppose.
At any rate, the Sledgehammer was a long standing benchmark for this level of street engine. Mine went tens of thousands of miles and hundreds of passes and never missed a beat. Even towing a trailer 3500 kms and cooking the engine along the way (that did eventually did kill the bottom end though).
If I had the nerve, the cam after the XE276, which was a custom grind on XFI lobes (intake: 224@.050", adv duration of 274), I would have spec'd a 108 LSA rather than the 110. I think it would have made a decent difference although with the XFI, it resulted in a personal best at the track.
Thanks for that bit of info Bill. I like digging into that sort of stuff.
blackbmagic
Sep 6, 2010 11:19 AM
88´TransAM
Aug 28, 2007 02:47 PM
12SecondTA
Oct 22, 2006 01:12 AM
snisbet375
Jan 17, 2003 02:59 PM
AFRGTA
Oct 12, 2002 09:16 PM
