Please help! 86 TPI Won’t stay alive.
Old Sep 15, 2021 | 06:36 PM
MattMostLikely's Avatar
Car: 1986 Pontiac Firebird
Transmission: Automatic
Hello, I recently purchased an 86 T/A with the 305 TPI as my first project car, however I can’t get it to stay running. I’ve tried putting in the following
-Fuel Pump, Sending Unit, Tank, and Filler Neck (which all is not getting power unless I run a wire directly to it)
-ICM
-Plugs and wires
-TPS
-Fuel Regulator
-New Fuses
-New Fuel Pump Relay
and even tested to see if I’m getting fuel to injectors (I am). Any help or info would be greatly appreciated! Thanks
Old Sep 15, 2021 | 07:45 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Please help! 86 TPI Won’t stay alive.
So, what's it doing exactly? Are you getting spark? What's the fuel pressure at? Have you ohmed the injectors? Gotten a datalog?
Old Sep 15, 2021 | 08:29 PM
Vader's Avatar
Welcome Aboard!
"Won't stay running" implies that it does run, if only briefly. Komet has the right idea - A little more detail and it will be a lot easier for us to point fingers at what should be checked.
Old Sep 16, 2021 | 01:36 PM
She’ll crank and start with ether for a couple seconds before dying, I haven’t got to test the pressure yet, waiting on my gauge to come in tomorrow, I plan on taking an ohm meter to the injectors today, since yesterday was the first day I got to use my NOID set.
Old Feb 14, 2024 | 11:15 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Deleted
Old Feb 14, 2024 | 12:57 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I think you meant to post this reply in the thread below. You probably got caught up in the related threads when you scrolled down and it jumped to this thread.
https://www.thirdgen.org/forums/tpi/...on-intake.html
Old Feb 14, 2024 | 01:58 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
85/86 TPI was flat tappet cam. 85 TPI was a L69 5.0L H.O. long block with TPI induction and 86 was a LG4 5.0L long block with TPI induction. 86 had the weakest cam ever put in a TPI engine.
Corrected thanks!
Old Feb 20, 2024 | 04:15 PM
dfarr67's Avatar
As to your first question about PnP, although it looks similar- it's quite different and a DynamicEFI ecu is a compliment or possibly a must have. There is no EGR. I didn't like his mono TB, all my fuel rails and AFPR and bored TB are stockish. I had an old Edelbrock TBI to MPFI conversion kit- if I had Rob's ecu, it still would be on the truck. Be mindfull you are going for torque- probably be disappoint in hp although I have a very mild roller cam.
formula_88
Nov 26, 2011 05:48 PM
slowest1
Jun 1, 2006 12:09 PM
