TFS-89024 - Trick Flow® TFX™ Fuel Injectors - Will it fit OEM manifold?
Old Nov 4, 2021 | 12:38 PM
Chris_Formula's Avatar
Hello folks,
short question, does anybody know the length of the OEM 1988 injectors (Bosch 3 for example)?
I want to buy the following injectors but Im not sure about the exact fitment.
https://www.summitracing.com/parts/tfs-89024
OEM Replacement:
No
Injector Advertised Flow Rate (lbs./hr.):
24 lbs./hr.
Injector Advertised Flow Rate (cc/min.):
255.0cc/min.
Injector Plug Style:
Jetronic/Minitimer
Injector Body Style:
EV1
Injector Impedance:
14.4 ohms
Driver Type:
12V saturated circuit
Overall Height (in.):
2.880 in.
Seat to Seat Height (in.):
2.270 in.
Manifold O-Ring Outside Diameter (in.):
0.573 in.
Fuel Rail O-Ring Outside Diameter (in.):
0.574 in.
0.943 in.
Wiring Harness Included:
No
O-Rings Included:
Yes
When they mean no OEM replacement, does it relate to the flow rate of 24lb/hr? Or do they mean the length? The measurements were given but I cant compare to an OEM injector yet. Hope you guys can clear me up
Greetings,
Chris
Old Nov 4, 2021 | 01:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TFS-89024 - Trick Flow® TFX™ Fuel Injectors - Will it fit OEM manifold?
I have a friend using trick flows, they can’t provide voltage offsets. Might consider access Holley has data .
Old Nov 4, 2021 | 01:58 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
99% sure they fit the manifold.
Agreed with Tuned, you'll want the voltage offset data. Accels provide this online. Cheaper too.
Old Nov 4, 2021 | 05:01 PM
Thanks for your answer guys. Could you explain that? What is meant by voltage offset? The PW vs. Battery voltage??
Old Nov 4, 2021 | 05:04 PM
Engine: Lb9
Transmission: M20
Just because they flow the same at 43.5psi not all injectors act the same . You will need to tune flow rate and offsets before you refine fueling. A lot more on this topic in the diy tuning and tuning guide
Old Nov 4, 2021 | 05:37 PM
To tune flow rate is clear for me but not offset. I will read myself more into this. But besides the tune, those injectors could fit physically and seal?
Can you recommend another brand of injectors? For example, what would be the differences between those trickflow and the Delphi 24lbs southbay provides?
Greetings,
Chris
Old Nov 4, 2021 | 05:45 PM
https://www.holley.com/products/fuel...e/parts/150824
Go down to technical specs and the time vs voltage graph is in there.
Old Nov 28, 2021 | 04:26 AM
Okay, so you convinced me to buy the new Accel 150824 since they are the newer modell with less trouble and the southbay are way more expensive and their 10% wont work for paypal orders outside of USA.
Question about the injector offsets:
Can I change the old values in the slot "injector pulse width correction vs battery voltage" with the new ones from the table accel is providing? Im asking cause of the units "usec added" the "u" stands for micro or milli seconds? Cause the values in the bin file are greater than the values in the accel table. Because of that im thinking its micro seconds and the other milli?
Old Nov 28, 2021 | 05:46 AM
Msec is a millisecond, usec is a microsecond.
https://www.timecalculator.net/milli...o-microseconds
That makes it extra easy to convert and plug in the number to the table.
decked
Oct 2, 2016 08:16 PM
southbay08
Jul 14, 2010 12:25 AM
FlamedROC
Oct 10, 2003 11:59 PM
mmcdjs
Sep 27, 2002 03:15 AM
Kenwood
Mar 24, 2002 02:56 PM
