89 Iroc no start hot.
Old Jan 23, 2022 | 09:45 PM
Random guy's Avatar
Car: 3 Trans Ams & an Iroc Z
Engine: All 4 are 350s
Transmission: Birds manual, Iroc auto
Axle/Gears: 342
My 89 350 Iroc cold starts fine, with 2 cranks. Once the engine comes up to operating temperature, after driving it a few miles, I shut it off. Take care of whatever business I have to, then return to the car. Turn the key & nothing. Fuel pump pressurizes the lines & that's all. Replaced the battery & starter. That was fun. Still doin the same thing. Once hot, no start. After about 3 hours, with the hood closed, it fires right up & runs fine. I'm sure that if I opened the hood, it would cool faster. Took it to a local shop & they couldn't find anything. Anybody here have any ideas? 49k mile car.
Old Jan 23, 2022 | 10:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 Iroc no start hot.
Sounds like you need to ohm injectors warm or could be icm breaking down. Need to test for spark fuel pressure and injector pulse warm.
Old Jan 23, 2022 | 10:07 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Nothing as in no crank, or nothing as in it just spins with no combustion?
My hot start issue was bad injectors. It's pretty common, I'd start by ohming them cold and hot.
Old Jan 24, 2022 | 04:11 AM
Random guy's Avatar
Axle/Gears: 342
Forgot to mention that the first thing I did was replace all the injectors, as 3 of them were hella clogged.
Old Jan 24, 2022 | 04:20 AM
Engine: Lb9
Transmission: M20
Clogged with what ? Rust and junk from
the tank ?
Old Jan 24, 2022 | 05:15 AM
Random guy's Avatar
Axle/Gears: 342
Rust. Replaced the fuel filter, drained the fuel tank & scoped it. Tank was amazingly clean for being 31 years old.
Old Jan 24, 2022 | 10:42 AM
Engine: Lb9
Transmission: M20
Have you tried using starter fluid when the no start happens ? The rust in fuel system is a concern hopefully not a repeat of previous injectors.
Old Jan 26, 2022 | 08:53 PM
Random guy's Avatar
Axle/Gears: 342
[QUOTE=Komet;6454775]Nothing as in no crank, or nothing as in it just spins with no combustion?
When I turn the key, nothing happens. It's like there's no engine under the hood. Total silence, outside of the fuel pump pressurizing the lines.
Old Jan 26, 2022 | 09:06 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
That sounds like a VATS problem maybe. Do you still use the key with the pellet in it? Do you have another key? Not sure what the hot start would have to do with it but seem like you've tried the usual stuff.
Old Jan 26, 2022 | 09:24 PM
Bill Hubbs's Avatar
Old Jan 26, 2022 | 09:40 PM
Random guy's Avatar
Axle/Gears: 342
Yes, I still have the factory keys with the black chip in them.
Old Jan 26, 2022 | 09:47 PM
Random guy's Avatar
Axle/Gears: 342
Originally Posted by Bill Hubbs
Failure to crank under those conditions could be a classic older Chevy problem. When the starter solenoid gets hot it requires more voltage to engage the starer than the factory (older) wiring can provide.
After the engine cools down some it will work again.
The solution I've used is to install a relay under the hood that is triggered by the start wire and connects battery power to the s terminal on the solenoid when activated.
Kits are available: https://www.summitracing.com/parts/prf-30202
Thanks for the suggestion & the link. I'm running out of ideas.
Old Jan 26, 2022 | 10:28 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Well, you can test if it's VATS by bypassing the start enable relay in the driver's footwell. Make a jumper out of thick wire and two male spade terminals. If it goes from no cranking to cranking after the bypass, you know that relay isn't being energized by VATS.
edit: VATS also disables the injectors so don't crank it forever this way if it does crank, this is just for testing.
I'd also recommend closely inspecting battery cables and all wiring going to the starter area for burns, breaks, splits, etc.
Old Jan 26, 2022 | 10:39 PM
Engine: Lb9
Transmission: M20
So now it’s a no crank or crank no start ?
Old Jan 26, 2022 | 11:16 PM
Random guy's Avatar
Axle/Gears: 342
Just replaced the original starter & I did check all of the cables for breaks. All were solid & in good shape.
Old Jan 26, 2022 | 11:21 PM
Random guy's Avatar
Axle/Gears: 342
It starts fine when it's cold, as in cold start. When it gets up to operating temperature & I turn it off, that's when it fails to do anything. Turn the key & nothing.
Old Jan 26, 2022 | 11:24 PM
Random guy's Avatar
Axle/Gears: 342
It's not my daily driver, so I can only work on it on weekends. I work long days & do not feel like beating my head against the car on week nights.
Old Jan 27, 2022 | 08:45 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Easy check when hot and no start. Turn headlights on, try the starter. If the lights go out and stay out you have a bad battery cable or connection. The high current draw of the starter opens the circuit, the current draw of the headlights keeps it open. Heat and resistance deal.
Old Jan 27, 2022 | 01:21 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I think the first thing to do would be to see if you are getting voltage to the starter / solenoid when you turn the key.
Old Jan 27, 2022 | 03:59 PM
southbay08's Avatar
which injectors did you replace them with?
Old Jan 27, 2022 | 04:09 PM
Engine: Lb9
Transmission: M20
this
Old Jan 27, 2022 | 07:41 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
I Had the same problem and change out the starter and it fix my maybe this will help you
Old Jan 27, 2022 | 07:59 PM
Random guy's Avatar
Axle/Gears: 342
Starter has been replaced. Did not fix the problem.
Old Jan 27, 2022 | 08:18 PM
Random guy's Avatar
Axle/Gears: 342
I'll check my records when I get home later tonight I keep extremely detailed records for everything I do to all of my cars. Takes the uncertainty out of the equation.
blue iroc
Sep 29, 2011 12:40 PM
89IROC2NV
Jun 5, 2008 03:49 PM
ROCFATHER
Mar 17, 2008 10:00 PM
N_IROC
Jul 22, 2001 11:56 AM
