305 TPI losing fuel pressure
Old Mar 17, 2022 | 12:31 PM
NastyNate85's Avatar
I just bought a 1985 Trans Am with a 305 TPI. It cranks but won't start. Checked spark at cylinder 1, have spark. Compression is about 135, just checked cylinder 1 so far. Spark plug is fouled. Fuel pressure is about 48 lbs with key on and cranking. Then fuel pressure drops slowly over the next few minutes. Im thinking an injector is stuck open. I found a set of 8 Bosch 19lb injectors on eBay for $47 new. Should I pull the trigger or do some more tests? Forgot to mention I took the regulator apart first and it looked fine and rubber was in good shape.
Old Mar 17, 2022 | 12:43 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 305 TPI losing fuel pressure
Pinch the return line and see if the pressure drop is the same. Imo, if the regulator gets opened, it gets a new diaphragm. Could be injectors, you can ohm them to determine if they're electrically ok. Does it pop a little with starter fluid? If not at all, might check timing as well.
Is it throwing any codes?
Old Mar 17, 2022 | 12:46 PM
350Iroc89's Avatar
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
I am chasing the same problem in my 89. There are 3 things it can be - Fuel pressure regulator, stuck injector, or bad check valve at the fuel pump. If FPR is ok that eliminates one potential issue. Don't buy cheap Ebay injectors as others have had problems with them. Southbay Injectors seems to be the go-to for injector replacements for TPI.
Old Mar 18, 2022 | 05:04 PM
I still lose fuel pressure with the return fuel line crimped. I tried pulling codes but the CEL doesn't light up at all, even when turning the key ON. Might have some dash light issues. I ohmed all the injectors, they all had between 15.5-16.9 ohms. I'm thinking I'll pull the distributor cap off and look at the rotor next. Might also make sure all the wires are in the correct position.
Old Mar 18, 2022 | 06:37 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Well, if the return is blocked, and you're losing pressure, the fuel is going somewhere it's not supposed to. Might very well be leaky injectors. Or leaky cold start injector? You could pop em out and verify.
Old Mar 18, 2022 | 10:24 PM
I didn't even know about the cold start injector. I will check that out tomorrow. After cranking for a few seconds I can smell fuel. Engine kind of tries to start a couple times and then seems to flood itself out. Ordered new spark plugs and FPR from rockauto today
Old Mar 18, 2022 | 10:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Don’t buy cheap injectors you get what you pay for.
southbay fuel injectors can hook you up.
Old Mar 19, 2022 | 06:09 PM
Cold start injector has 4.0 ohms. Fixed the wiring harness to the fuel pump relay. Replaced the relay. Still won't start. Waiting for my noid light kit from eBay. I'm not getting any dash lights when I turn the key ON. What's the best way to test the ECM? The 5 and 3 ohm fuses do not have power with key ON. I assume one of these is ECM. But the white letters are all worn off the fuse box
Old Mar 19, 2022 | 06:52 PM
Engine: Lb9
Transmission: M20
Ecm fuse is next to battery, check your fusable links at the starter if no power at the fuse box.
ecm
has accessory power and keep alive from battery. Look at 1226870 schematic
Old Mar 19, 2022 | 06:55 PM
Engine: Lb9
Transmission: M20
https://www.eecis.udel.edu/~davis/z2...ody-wiring.pdf
Old Mar 20, 2022 | 12:32 PM
ECM fuse is good, 12 v each side. Relay is getting power and ground in/out. I started checking ECM pinout with my power probe. I have all the necessary power and grounds with one exception. The Burn Off Relay Control has 0v and it's supposed to have 12V with key ON. I see that it's up under the dash pad above where I pulled the ECM from. Maybe this Relay box needs to be replaced. I'll have to get to it and check the wiring. Also realized my keys don't have a resistor in them. The car still runs the fuel pump and cranks but obviously won't start. Ignition looks old, so maybe I simply need to buy some resistors and try to find the correct one to wire into VATS, although I have not located that orange wire yet.
Old Mar 20, 2022 | 12:41 PM
Engine: Lb9
Transmission: M20
You don’t have vats
Old Mar 20, 2022 | 12:57 PM
Good to know. What are your thoughts on a bad Burn Off Control Relay causing a no start issue?
Old Mar 20, 2022 | 01:14 PM
Engine: Lb9
Transmission: M20
The car would still start without burnoff or without maf if tps signal is good.
i honestly wouldn’t try to start without basics spark and injector pulse verification.
a new fuel pump and good quality injectors cheap parts you will have issues .
Old Mar 20, 2022 | 05:34 PM
I read a thread on a Corvette forum where it said the engine would not start with a bad Burn Off Control Relay on an 85 because they are different from the later models. Not sure what to believe at this point. Previous owner replaced fuel pump. He cut a damn access door. At least I can test the wiring easily. That all looks good. I'll wait for my noid lights and new FPR before making any other decisions, but might have to update the car to 86-89 ECM and relays.
https://www.digitalcorvettes.com/threads/burn-off-mod-fix-for-85.26380/
Old Mar 20, 2022 | 05:54 PM
Engine: Lb9
Transmission: M20
I had a 85 with a bad maf, would start so who knows. The 870 to 165 ecm
is a good swap .
Old Mar 24, 2022 | 05:50 PM
I went thru all the wires on the ECM and found one irregularity according to the diagram. The Park/neutral safety switch is supposed to have 12v with key on, and I have a ground instead. I pulled the center console apart to look at the switch. The yellow wire on top is grounded when in park or neutral. Purple wire under yellow wire is constant ground. Found pink/black wire that runs to ECM and it had ground so I gave it power with the power probe and cranked. Still won't start. Used a noid light and confirmed injectors are getting power and ground but the light was kind of weak. Had a battery charger going at 2 amps. I still don't have any dash lights when I turn the key on and can't pull any check engine codes. I think that has something to do with the no start issue. Maybe the ECM is dead?
Old Mar 24, 2022 | 07:00 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
If you're losing fuel pressure with the return line crimped, where is the fuel going?
Old Mar 24, 2022 | 09:07 PM
Leaky injector I assume. No leaks from fuel lines. I would think the car would still start with a leaky injector. Probably run shitty but still run
Old Apr 4, 2022 | 07:20 PM
I am going to upgrade to a 165 ECM. I know I need 2 relays with pigtails, ECM and PROM. Who can I go to for PROM programming? Im grabbing a Lisle repin tool as well. Anything else I might need? Found an old website with some good info, just want to cover my bases. Thanks
https://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old Apr 6, 2022 | 11:18 AM
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/19495869663...mis&media=COPY
Few people here that do tpi programming
Old Apr 7, 2022 | 10:26 AM
Engine: Lb9
Transmission: M20
https://tpiparts.net/inc/searchresul...Relay&n=638430
Old Apr 7, 2022 | 03:01 PM
Engine: Lb9
Transmission: M20
I have a parts harness or can snip pigtails off a 86-87 harness for parts only but maf burnoff pigtail is junk
Old Apr 8, 2022 | 03:10 PM
Engine: Lb9
Transmission: M20
believe you also need a analog maf the digital one might not work with the 165
Old Apr 8, 2022 | 04:22 PM
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/14449449134...mis&media=COPY
Old May 10, 2022 | 01:25 PM
Replaced the ECM and relays to the 88-89 style and got the car running. Seemed to run well, maybe idles a bit high.
Old May 10, 2022 | 02:35 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Mine did that too the first time I got it full of coolant and pressurized. Did the oil turn into milkshake, or is there oil in the coolant now? If it all looks good, let it cool down, suck up all the fluid it wants, then check the coolant in the rad and the overflow again and try again. A lot of my very early symptoms stopped reproducing after the engine had a few heat cycles. Just monitor it really closely and do several short test drives.
Old May 10, 2022 | 04:11 PM
Engine: Lb9
Transmission: M20
I’d fix the overheating or air bubble that burped first. If still 1226870 a Vette prom
will work for the swap iirc hlh3200 are the letters for it .
Old May 11, 2022 | 05:34 PM
Removed the thermostat, changed the oil (no milkshake in oil or coolant) topped off radiator and let it run with the cap off for a while
Old May 11, 2022 | 05:58 PM
Engine: Lb9
Transmission: M20
Before the radiator cap was put on was it ran until t stat opened and topped off ?
Old May 11, 2022 | 06:12 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Hmm, how hot is it getting when it boils like that?
Old May 12, 2022 | 05:50 PM
I had another "Doh!" Moment with this car. The fans were simply not turning on. I didn't have the relay wired correctly. I'll fix that tomorrow and report back. Can't believe it took me this long to figure it out
Old May 13, 2022 | 11:35 AM
Turns out the wiring was good, relay is working, but the fan doesn't turn on. Used a power probe to check power/ground and it's getting there but fan motor is burnt out. Trying to find a new fan now
Old May 13, 2022 | 11:45 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You should be able to replace just the motor part.
Old May 16, 2022 | 09:39 AM
Couldn't get the nut off the fan to remove the fan from the motor. Even with an impact and holding the fan it just spins the motor behind the fan so the nut wont come loose. Does anyone know of another fan from a more common car that would fit in my Trans Am? Would be nice to run to the junkyard and grab a fan. I can re wire the fan as long as it physically fits behind the radiator without hitting any pulleys or the air box/tube.
Willdak89
Aug 16, 2016 10:22 PM
s10sbc350
Feb 2, 2013 09:46 PM
dctrouant1995
Aug 13, 2011 10:58 AM
tanager11
Aug 24, 2009 09:39 AM
hedgejj
Apr 29, 2007 04:15 PM
