No crank, l when i turn key
Old Aug 30, 2022 | 10:58 AM
Pbarnett98's Avatar
Car: 89 Iroc
Engine: 388CI Paxton supercharger
Axle/Gears: 4.10
Hey everyone, I did a stupid thing and hope you can help. I have an 89 iroc with a 383, new holley computer. it was running rough like there was interference coming from somewhere. So i unplugged the stock computer to see if it would start without that connected. No power at all while turning the key. So i plugged the stock computer back in and i still have no power when turning the key. I checked the connectors for bent or damaged pins and they all look fine. Then i realized i never disconnected the battery when pulling and reconnecting the plugs to the stock computer. I know stupid!!!! Is there any known fuses that i could have blown while doing this?? Any help would be greatly appreciated
Peter
Old Aug 30, 2022 | 11:04 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No crank, l when i turn key
When you say no power does interior lights work , headlights ?
or just no power to starter when trying to crank ?
Old Aug 30, 2022 | 11:20 AM
Pbarnett98's Avatar
Car: 89 Iroc
Axle/Gears: 4.10
Lights work, No power to crank when i turn the key forward.
Old Aug 30, 2022 | 11:33 AM
Engine: Lb9
Transmission: M20
Have you bypassed the starter enable relay?
Old Aug 30, 2022 | 12:31 PM
Pbarnett98's Avatar
Car: 89 Iroc
Axle/Gears: 4.10
I don't know what that is, So no i haven't.
Old Aug 30, 2022 | 01:00 PM
Engine: Lb9
Transmission: M20
The car was originally equipped with vehicle antitheft system. The passkey module controls the starter enable relay located under the drivers side kick panel. Test fir power while cranking or bypass.
Old Aug 30, 2022 | 08:00 PM
Vader's Avatar
Regarding the first question, while it is always advisable to disconnect the battery before the ECM, not doing so does not necessarily result in damage to the ECM. Chances are the ECM was not damaged at all.
Second, when the key cylinder is turned forward to crank, what happens to the temperature gauge and warning indicator lamps? If they do not operate (bulb test mode) there may be an issue with the ignition switch and/or its adjustment. One possibility is that the ignition switch is not being actuated fully. The key cylinder connects to the ignition switch via a linkage rod. If the IROC has a tilt steering column there are additional components in the actuator system, and some of those are more prone to wear (die cast material). To minimize any slack in the linkage with a tilt column it may help to position the steering wheel in its lowest position before turning the key cylinder.
Old Sep 4, 2022 | 11:15 AM
Pbarnett98's Avatar
Car: 89 Iroc
Axle/Gears: 4.10
I bypassed the starter enable relay and she started right up.. Thank you. Now my question is what is my best path forward from here? How do i fix this issue? is it as simple as connecting those 2 wires together permanently? Is there a better, more professional way to fix it?
Thanks,
Pete
Old Sep 5, 2022 | 08:05 AM
Vader's Avatar
It would be best to determine whether the start relay has failed contacts or is not receiving power to the coil. There could be a problem with the neutral safety/clutch safety switch, VATS, ECM connections, or other wiring maladies.
Old Apr 10, 2023 | 09:03 PM
Engine: Lb9
Transmission: M20
Old Sep 22, 2023 | 07:58 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
@chazman did you try this?
Old Nov 13, 2023 | 11:29 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Is there anything that would keep the starter enable relay from working, besides the VATS?
Old Nov 13, 2023 | 11:30 AM
chazman's Avatar
Axle/Gears: BW 3.45
Yes, cranks but won't start when jumped.
Old Jan 4, 2024 | 05:57 PM
Nsty_6.2's Avatar
Car: 1989 Chevy Camaro
Engine: 6.2 376l LS3
Transmission: 4L80E 3k stall
check your neutral safety switch if left unplugged or bad your car won’t start
Old Jan 9, 2024 | 11:54 PM
Eightyninef's Avatar
It's 2 years old. Sure hope he figured it out by now. Probably VATS at the lock cylinder.
johnjm22
Aug 13, 2021 05:04 AM
gta90
Mar 7, 2021 08:19 AM
SketchyZed
Apr 18, 2017 07:42 PM
Rakim_RS25TH
Jul 5, 2015 10:48 PM
ThirdGen Stoner
Jan 10, 2003 05:46 PM
