another no injector pulse problem
so i have this 88 gta 5.0 which has been stored since 2008 with a no start problem, so far i have replaced :
-injectors from southbay
-new dizzy and icm from rockauto
-new fuel pump and filter
-new fuel pump relay
fuel pressure is 40 psi at the rail with key on
verified that i have spark
so now i checked with a noid light that i have no pulse at the injectors , i do have 12v
both fuses are good and receive 12v also
fuse by the battery is also good
tps is at 0.54v
the 2 wires from the ignition coil to the icm are also good
the vats light does not stay on but i dont have a check engine light, doesnt come on at key on, bulb is ok
the other light there also doesnt come on ( i have a digital dashboard )
and the odometer lights up but displays no numbers
so....anybody have some ideas?
tps is at 0.54v
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: another no injector pulse problem
I would think that’s close enough to 30hz the ecm
should enable injector pulse.
Engine: Lb9
Transmission: M20
Maybe check post 4 and test, could be a bad icm
https://www.thirdgen.org/forums/dfi-...pulse-ecm.html
Engine: Lb9
Transmission: M20
Btw ref high is purple/white wire at icm
Engine: Lb9
Transmission: M20
Should be giving the right signal 400 plus rpm it should enable injector pulse.
Do you have a scanner to connect to ecm to see if it’s showing cranking rpm ?
no dash mil light to show any codes ? Vats I’d think would work not sure why no pulse . Grounds tight behind passengers side cylinder head ?
I know you had fuel pressure is ecm
doing a 2 second pump prime key on ?
is there a way to check if it gets power?
grounds are tight.
it does prime the pump also disconnected the fuel line and while cranking the pump pumps fuel no problem
Engine: Lb9
Transmission: M20
The ecm sounds powered up , but can double check. The ecm has 2 constant hots and an accessory power. B1,C16 orange wires hot all the time a6 accessory power turn on.
the mil is a5. Can always use a test light hooked to power one end other on a5 to see if you dash bulb is burned out and blink codes.
put in the paperclip in port a and b and then looked with the test light but no blinking just constant light also the bulb is ok in the dash
Engine: Lb9
Transmission: M20
With the rigged up test light ground pin a9 at the ecm. This bypasses the wiring for aldl and commands check engine light diagnostic mode. If still a solid light I’d think the ecm is faulty.
yep still a solid light, do you have a 1227165 in stock or know someone with a working one?
Engine: Lb9
Transmission: M20
I do have a few 1227165 but cannot test them, I’m not sure of anyone with a used one either. Can always post in classifieds wanted section.
