WOT Issue
Old Jan 25, 2024 | 05:11 PM
hassgrant's Avatar
Car: '91 Z28 305 TPI
Transmission: Manual
WOT Issue
I have a 305 TPI and I just put new o-rings in my fuel rails (was leaking fuel) and replaced FPR.
Once I put everything back together and started the car, she goes straight to WOT. The physical throttle does not move.
Any suggestions?
I never had this problem before I changed o-rings and FPR. Car actually ran really well other than the slight fuel leak that made her stink. O-rings in fuel rail were pretty bad.
Old Jan 25, 2024 | 05:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: WOT Issue
Large vacuum leak
Old Jan 25, 2024 | 05:32 PM
hassgrant's Avatar
Re: WOT Issue
Thank you!
I'll diagnose tomorrow. It is possible I didn't hook something up.
Funny, I thought vacuum leak would cause opposite problem.
I'll update tomorrow.
Old Jan 25, 2024 | 06:39 PM
Engine: Lb9
Transmission: M20
Re: WOT Issue
Originally Posted by hassgrant
Thank you!
brake booster line hooked up ? Vacuum lines on fpr and hvac as well as map ?
if throttle blades are closed and the engine runs away you have a vacuum leak. Gasket leak or one of the gaskets is in the wrong place . You can seal up the Throttlebody with a latex glove and smoke test the intake .
Old Jan 26, 2024 | 10:06 AM
hassgrant's Avatar
Re: WOT Issue
I can't say 100% what the problem was.
I believe I had the vacuum line from the EGR solenoid to the underside of throttle body kinked by the front fuel rail. She is back to normal now. Decided to detail engine (had to get rid of the paint shops paint dust anyway).
Old Jan 26, 2024 | 07:41 PM
Engine: Lb9
Transmission: M20
Re: WOT Issue
Beautiful engine compartment, don’t see how ported vacuum could cause the engine to race.
Old Feb 8, 2024 | 06:16 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: WOT Issue
I agree with Tuned Performance. I find it hard to believe that a ported vacuum line as small as the EGR could cause the motor to race. For a motor to do that it has to have fuel and air. Great that your problem is solved. Would not be a happy situation if it happened on the highway. That is what happened to me with my 305 carbed Monte Carlo SS before I did the 350 TPI swap. I was on the highway and suddenly the motor was pulling hard. I went to neutral and the motor raced all the way to beyond redline. Put it back in gear and laid on the brakes and after about 3 - 4 minutes the stock brakes were completely faded and useless. I put the trans back in neutral and turned the key "one" click to off. Then coasted to the shoulder and hit the brakes with both feet and took over 100 feet for the car to coast to a stop. Reminds me of a scene in the movie Blues Brothers. Real scarry. I looked under the car and noticed that the catalytic converter was cherry red hot. I have read that condition indicates that the CAT is seeing raw fuel. Had to have it towed. Got it home, cooled off, started the motor everything was fine. That was the day when I decided to pull the motor and go 350 TPI. Never looked back. Never found out what was wrong. I think it had something to do with the secondaries dumping fuel into the manifold, but I checked everything and all appeared ok. Weird.
Cadillacbart
May 23, 2021 08:13 PM
NZKnight
Dec 17, 2018 04:05 AM
rraccerr
May 2, 2013 02:48 PM
87_TA_GTA
Apr 12, 2011 11:13 AM
Ebby
Jul 24, 2005 01:47 AM
