upgrade is stuck: I removed ALL the Plenum bolts, can't remove it!
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
Friends,
I'm doing an injector upgrade and a Throttle Body upgrade. (YES i have a custom tune on my MS3PRO and I have my tuner standing by to tune the car.)
But. I have removed all 8 bolts (and even some extras), following the directions (my car is a 87 IROC) found here: https://www.thirdgen.org/injectorswap/
But the plenum will not budge, i cannot get it to move and so i've moved on to removing the runners and see if that buys me anything (but sadly, one of the runners has an inside bolt to it that I cannot get to).
SO. Does anybody have any suggestions??
Brian
Brian
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: upgrade is stuck: I removed ALL the Plenum bolts, can't remove it!
Smack the plenum with a dead blow hammer if bolts are removed from the sides.
Car: 1987 IROC Z/28
Car: 1987 IROC Z/28
BOOM.
Dead Blow hammer was the ticket. I just try to be gentle with Aluminum. But i went and bought a Dead Blow hammer from Lowe's and boom.. problem solved. thanks for that tip guys.
