EPROM
Old Jun 14, 2024 | 05:33 PM
Astojim's Avatar
EPROM
Hi, I’m after a chip that will allow for air pump delete, EGR valve delete, and cold start delete, I cannot find anyone in UK that can help, so I was hoping a could order one already done.
Thanks Jim
Old Jun 14, 2024 | 05:43 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Re: EPROM
I really don't know anything about the OBD1 chips but.............is that possible?
Old Jun 14, 2024 | 06:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EPROM
It really won’t make to much difference if that’s all that has been deleted you might get a 32 code for egr delete but no horrible running conditions if not addressed in a tune .
Old Jun 14, 2024 | 09:15 PM
Vader's Avatar
Re: EPROM
Of course that can be done, but it's not just a matter of a UV-PROM set up and burned the way you like it. The original DIP needs to be removed and the replacement installed. That can be done with a DIP socket, or a complete new MEMCAL with a socket. I've always just done my own.
Old Jun 14, 2024 | 09:38 PM
Re: EPROM
Wow, that sounds like a bunch of Greek to me lol!
I guess when I get around to my TPI S10 Blazer build I'll have some learning to do!
Old Jun 15, 2024 | 04:40 AM
Astojim's Avatar
Re: EPROM
Hi what do you do and what do you need to do your own
Old Jun 15, 2024 | 03:53 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: EPROM
There's a few ways to approach this...
I've done this many moons ago but mine didn't turn out that pretty!!! I used a zero insertion force socket with quick release lever instead. If there was no need to preserve the stock tune on the stock EPROM, you could possibly peel the silver sticker off and expose it to good ole Hawaiian sunshine (well in my neck of the woods/beaches) or a much quicker UV eraser. However you would need a adapter/header. ...BUT be FOREWARNED that not all burners can write to the OEM UV erase style EPROMs. APU1/Autoproms and the Burn2 are examples of burners that don't do the UV erase style EPROMs.
You can also use this adapter that bypasses the OE EPROM. In the linked pic, you can see a EEPROM that can be electrically over-written meaning it doesn't require a UV eraser.
You could do a one and done Email ordered tune but if you think you might need the capability or future tunes...what I'm alluding to is explore all your options before you spend your hard earned $$$.
Old Jun 17, 2024 | 03:32 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Re: EPROM
Back in the day, I used Tunercat. I think they are still in business. I'm going back to the Craig Moates era!
https://www.thirdgen.org/forums/diy-...roms-more.html
KCG
Jun 21, 2017 04:21 PM
3rdgenmaro
Jan 3, 2017 01:12 PM
