1987 MAF QUESTION
Old Jun 19, 2024 | 01:37 PM
87gtaredonred's Avatar
1987 MAF QUESTION
Hey guys!!! I'm thinking I might have a bad maf, car runs fine but will occasionally throw a maf code. I have read so much about MAF sensors now till my head is about to explode. From what I'm understanding 87 was a change over year for MAFs?? The part number on mine is a Bosch 14094712 which im 99.9% is original. I went to Advance auto, Auto Zone, and oreillys and bought what they said was the correct MAF with those MAFs installed the car wont even start just cranks if it starts just stalls right back out. Which tells me Im not getting the right part. I'm assuming I have the early style MAF. Do I need to order a MAF for like an 85 or 86??? I'm kinda stumped at this point. Thanks in advance for all the help
1987 GTA 5.7 red on red
Old Jun 19, 2024 | 01:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1987 MAF QUESTION
85 is a one year only digital maf, 86-89 are analog. There are a few different part numbers for the 86-89 mafs 3 different ones i think but I’ve had good success recently with Delphis maf. Af10320.
Old Jun 19, 2024 | 01:45 PM
Engine: Lb9
Transmission: M20
Btw what code was it throwing 33 , 34 or 36 ? How was it diagnosed the maf was the problem?
Old Jun 19, 2024 | 01:52 PM
Thank you and yessss my MAF part number points to that one on Rock Auto, I'm gonna return this one to oreillys and do some more digging and maybe buy this one.
Old Jun 19, 2024 | 01:57 PM
Random code 36, changed and swapped some relays according to the flow chart, runs fine till it decides to do it again, restart the car and runs fine till pops up lol. Just so random. Ive check wiring as far as I can tell everything is perfect. Car is 60,000 all original, never messed with.
Old Jun 19, 2024 | 02:01 PM
Engine: Lb9
Transmission: M20
Could be an ecm not detecting the burn off . Some mafs made for tpi have no burn off wire. Not sure why a manufacturer would do that .
Old Jun 19, 2024 | 06:48 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I have a Rich Porter MAF on my TPI. I bought it many years ago from Rock Auto. It does not have a hot wire in it. Instead, there is a circuit board with what looks like a small heat sink. I have never got a MAF error since installing it. Let me knock on some wood right now.
Fred
Old Jun 20, 2024 | 12:06 PM
Gunmetal87's Avatar
Car: 1987 GTA
Engine: 5.7L
Really? I thought I read in these forums over the past years the delphi MAF’s were giving ppl issues. Was there a recent change in design or something with them?
Old Jun 20, 2024 | 12:12 PM
Engine: Lb9
Transmission: M20
the last 3 that I’ve had customers install work fine. What’s your suggestion?
Old Jun 20, 2024 | 12:29 PM
Gunmetal87's Avatar
Car: 1987 GTA
Engine: 5.7L
I don’t have a suggestion. I replaced my original with a cardone rema 744712 and it worked fine for a bit, but might be giving me issues again. I need to check timing and compression first before thinking it might be the MAF again. So just knowing what MAF to go with should I need to replace it again is great to know
1701-Z
May 31, 2016 09:32 PM
QuickGlass
Jun 7, 2010 09:45 PM
badblackiroc
Feb 1, 2009 03:32 PM
Francis
Sep 7, 2006 01:08 PM
Z28DJP1987
Nov 29, 2001 09:50 PM
