.100" longer pushrods with Edelbrock heads?
Old Jan 27, 2002 | 08:08 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I was wondering if it is needed to run .100" longer pushrods with the edelbrock performer heads #60859? Is it neccesary with the Trick Flow 23 degree heads too?
Old Jan 27, 2002 | 08:58 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I installed #6089's. Stock l98 block, Edelbrock recommended gaskets (felpro), and the stock length factory roller pushrods provided the correct geometry (I used a pushrod, value angle checker ... looks like a plastic rocker arm).
Best thing to do is to buy on of these and measure your setup.
If you need an inexpensive set of "hardened" pushrods for a factory roller, comp cams has a set ... cheapest I found. Email me if you want the part #.
Mark.
Old Jan 28, 2002 | 03:51 AM
TA88GTA's Avatar
i used the stock lenth pushrods too but i got the Performer RPM's dont think theres any difference thou
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
