what cam for this mean 305 tpi
Old Feb 4, 2002 | 07:36 AM
redtail2426's Avatar
I have a 305 tpi motor with sr torquer heads,slp headers,high flow runners and plenum,2400 stall converter,373 gears,its a 700 r4,and i have all the free mods.I need a cam for this thing want to know what would work best with the mods i have.thanks
Old Feb 4, 2002 | 08:35 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
For your application something around 208-224 duration, and no more than 465-480 lift.
SLP makes a decent grind. part number is 51006 I think.. Its something like 208/212 duration. Lift isn't too high either.
Those heads are not the best in the world, and don't flow all that much IMO..
-- Joe
Old Feb 4, 2002 | 11:35 AM
Oh wow i thought those heads would be good a couple other people have said good things about them.What heads would you recommend.
Old Feb 4, 2002 | 01:11 PM
custman87T/A's Avatar
I have the mods below and love my 305 this way. I am building a 350 for when I blow this up but for now it is a HUGE difference over stock
Old Feb 4, 2002 | 01:44 PM
Did you have your sr torquer heads ported a little around the bowls i read some posts and people say u have to open up the bowls or something.How much does that cost average. thanks
Old Feb 4, 2002 | 02:09 PM
I purchased unassembled heads and assembled myself with the springs from the summit cam kit and Manley valves . The only areas I took my dremel to were the runners, there was some casting material in there that needed to be cleaned out.
Old Feb 4, 2002 | 11:58 PM
David 91RS/Z28's Avatar
I ran a Comp 210/220 .480/.480 112LS camshaft with untouched vette heads, stock ported TPI, headers, exhaust, etc. with very good results. Best on motor was 13.65 @ 101.xx mph. Dynoed 240rwhp and 308rwtq behind a 5speed.
Old Feb 5, 2002 | 06:27 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The S/R's are really not much better than stock 58cc castings IMO.. I dunno what I'd run on a 305.. Prolly those or just ported stock heads.. 305 is touch to build up.. I've done it for fun, but never got much out of them.
-- Joe
Old Feb 5, 2002 | 10:53 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I just finished putting in a crane 2032 cam 214/220 ~.500" lift with 1.6 roller rockers and a siamesed base. Only ran for a few days now and needs some tuning still, but with 5* base timing and a little higher fuel pressure, it pulls hard to 5300-5500 rpm where my SLP chip cuts off(@5500rpm). This is a '89 305 TPI 5 speed with 3.42 gears. With the stock cam (207/213?) and stock manifold base, it would start to die somewhere between 4400-5100(hard to tell) Definately higher now. I did lose some low end though like below 1500rpm the car isn't happy in any gear other than 1st.
Hoping for a 13 or really low 14s at 99+.
Old Feb 5, 2002 | 09:20 PM
Anyone think the comp cam xe 256 would be good.Duration 212 to 218 with .449 to .456 with 112 lsa.Anyone else think this would be good.
Old Feb 5, 2002 | 11:11 PM
Forgot to mention this setup was on the original 305 engine and not a 350. I sure miss that little sucker. Suprised the hell out of people when I told them it was only a 305. With a little shot of nitrous(80hp) went 12.8's at 109.5.
Old Feb 6, 2002 | 06:40 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey David,
I was going through your side. Looks like when you swap motors, you leave the tranny in the car and do the same trick I do.. ??
-- Joe
Old Feb 6, 2002 | 11:22 AM
David did u have to do anything to the computer for that cam or did it all work out with the stock chip in there.
Old Feb 6, 2002 | 11:37 AM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
I also have the 2032 in my 305.. i like it but I have to agree with beast, you lose some low end below 1500, but pulls like a sonofabitch from 2000rpm+ but with your high stall converter that should help fix that problem a little for you... I recommend the 2032, it was easy to install, good roller cam, car runs alot better with it, little bit of a rough idle though.... does't like my stock chip... had to put in a PR chip.. Have fun
Old Feb 6, 2002 | 06:24 PM
I had a custom chip burned which definitely helped a little on the performance. I actually ran the stock chip when I sprayed the car at the track as it had less timing. Driveability was good with either chip.
Old Feb 6, 2002 | 08:57 PM
I think i am gonna go with the comp Xe 256 i listed the specs above.Would want 1.5 or 1.6 roller rockers?? thanks for all the cam help too.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
